Dropbox [AppStore]
Honzam
Dropbox [AppStore]
Příspěvek od Honzam »
Na AppStore se konecne objevila aplikace Dropbox pro pristup k webovemu ulozisti dat...
Vice na https://www.getdropbox.com/iphoneapp
Stahnout na itms://itunes.apple.com/WebObjects/MZStore.woa/wa/viewSoftware?id=327630330&mt=8&s=143441
Edit: Aplikace je free a je nutne mit fw 3.1
Naposledy upravil(a) Honzam dne stř zář 30, 2009 8:21 am, celkem upraveno 1 x.
shauriq
Re: Dropbox [AppStore]
Příspěvek od shauriq »
neskoro... :D vcera som si zaregistroval sugarsync...
pharlap
Příspěvek od pharlap »
A jeste dodam..
1/ze aplikace je pro lidicky, co maji FW 3.1 8)
2/ Je FREE
Pozn.: Taky sem ji chtel sosnout, ale jelikoz mam 3.0, takže smolíík :-/
Tea Racer
Příspěvek od Tea Racer »
Opravdu dobrá aplikace. Už ji také mam. Doporučuji. :-)
iPhone SE 2022
Rumsound
Příspěvek od Rumsound »
Konecne!!! Tohle mi chybelo ke stesti...
iPhone 4 16GB iOS 6.1 no JB
iPad2 16GB wifi iOS 6.1 no JB
ivane
Příspěvek od ivane »
Zanedlho vydaju update aj s podporou 3.0
hi guys,
thank's so much for all the praise and downloads (over 75k installs in the 24 hours after launch! :)
this is just the 1.0 and we realize there are many, many features to add and bugs to fix (zoom in photos, folder favoriting, etc etc :). we also hear you loud and clear on the 3.0 restriction. we didn't realise it'd create such an uprising!
we opted for 3.1 because API methods related to saving videos were not available on 3.0. this meant that videos taken within the app would be permanently lost in the event of a flaky/slow internet connection. this happened to us enough in testing that we felt it wasn't a risk we wanted to expose to our users.
that said, it looks like there's a workaround that'll allow us to protect against this for 3.1 users while still allowing 3.0 users to use the app. we're hoping to get a quick maintenance release out with a few small bug fixes + 3.0 support.
please continue to provide feedback - we're listening!
http://forums.getdropbox.com/topic.php? ... replies=25
Coolman
Příspěvek od Coolman »
Dnes jsem to rozjel a opravdu fantazie. Mám 3PC a iPhone - neexistuje snad lepší řešení, jak mít všechno pohromadě. I ty 2GB prostoru jsou na veškeré dokumenty dostačující.
spachal
Příspěvek od spachal »
Dropbox doporucuji pouzivat i pro synchronizace, diky mapovani na adresare v pocitaci se da vyuzit i pro beh ruznych aplikaci se stejnymi daty, mimoradne uzitecna funkce ..
To ze je portace i pro iPhone, je jedine dobre :]
terry
Příspěvek od terry »
Nenašel jsem v Dropbox app možnost například uložit obrázek do telefonu. Pouze jsem špatně hledal, anebo tam tahle funkce opravdu není? Ve webovém rozhraní to totiž normálně lze a někdy by se to hodilo.
toncek
Příspěvek od toncek »
Dropbox je nyní dostupný i pro fw 3.0. :arrow: Už je v iPhonu
iPhone 6 16GB
iPad 4 32GB
-jb-
Příspěvek od -jb- »
o dropboxu jsem se rozepsal nedávno zde:
http://www.[zakázáno]/aplikace/dropb ... na-iphone/
je to opravdu výborná věc a všem ji doporučuju. víc v recenzi
toncek
Ano, jíž více jak rok používám Desktop verzi - opravdu výborná věc :)
iPhone 6 16GB
iPad 4 32GB
mrzic
Příspěvek od mrzic »
Taky jsem přišel na chuť DropBoxu. Chci vystavit fotky, dám je do PHOTOS a pošlu link. Chci někomu poslat soubor, dam ho do PUBLIC a pošlu link. Do 3 GB je zdarma (standard 2GB, ale když pozveš někoho dalšího a on se zaregistruje, zvýší Ti prostor o 250 MB). Navíc vše funguje na portu 80 a 443.
iPad Pro 10.5, iPadOS 14
iPhone 12 Pro Max, iOS 14
missik
Příspěvek od missik »
Neviete nahodou ci sa da a ak ano, tak ako, ukladat obrazok z Dropboxu do iPhonu? Ako napriklad v Safari ked prezeram a podrzim prst na obrazku, tak mi vyhodi moznost ho ulozit???
atirita
Příspěvek od atirita »
Tak ja to robim prave cez safari :D
Zadas dropbox.com a normalne sa prihlasis.
Myslim si, ze vo phone to je jedno ci pouzivas app alebo pristupujes cez safari.
Obrázek iPhone 4 16GB iOS 5.1.1
Obrázek iPad 1 64GB+3G iOS 5.1.1
Ked ulozim XLS, DOC a pod. do dropboxu, tak v tejto app ich viem otvorit?
atirita
PDF ide otvorit normal to som skusal ...
ostatne vyskusam a dam vediet :wink:
tak potvrdzujem ... v dropboxe ide otvorit XLS aj DOC aj RTF aj PDF
edituj svoje příspěvky a nepostuj jich více pod sebou. viz pravidla fóra. Rovněž prosím používej pouze defaultní barvu fontu. Děkuji toncek
missik
ano je to tak idu otvorit aj wordowske dokumenty a tiez aj z wordu 2007 (teda docx, xlsx a pod.)
no a ide ukladat tie obrazky cez Safari ako vravi Atirita - co je dobre, ale mohlo by to ist tiez cez tu App, to by potom bolo uz dokonale.. :)
JackieTran
Příspěvek od JackieTran »
vyborna aplikace,presne tohle u IP chybelo! Funguje jako u ostatni tel. staci dat do IP nejakou vec,soubo a v tel se to otevre. moc se mi libi
toncek
rony píše:Ked ulozim XLS, DOC a pod. do dropboxu, tak v tejto app ich viem otvorit?
Rony když tak se koukni na jejich webu https://www.dropbox.com/ mají tam nějaká videa. Jinak samozřejmě na webu je o této službě dostatek informací, pokud neznáš a zajímá tě..
Osobně ji používám již více jak rok a jsem spokojen. Ze všech počítačů a nyní taky z iPhonu mám prakticky přístup ke všem svým důležitým souborům. Někomu nevyhovuje, že je potřeba mít tyto soubory ve zvláštním adresáři, ale tohle mě osobně netrápí.
iPhone 6 16GB
iPad 4 32GB
raider
Příspěvek od raider »
A z jakého důvodu nejdou zoomovat fotky,když dokumenty jdou????? :shock:
LosGalacticos
Příspěvek od LosGalacticos »
nevite nekdo proc kdyz si ulozim na dropbox napr 10 prezentaci v powerpointu...a pak kdyz si je potrebuju otevrit na IP tak tam mam napr pouze 6....tohle se mi stalo nejen u prezentaci..proste nahraju urcitej pocet dokumentu a pak jich tam ma daleko mene.. :-( nevite jak to vyresit?
atirita
Vyskusaj pristupovat cez safari ja to tak robim stale. cez neho mozes aj stahovat foto do phonu ;)
Lukas1107
Příspěvek od Lukas1107 »
dropbox uz dava az 10GB zdarma za Referrals
Kdyby nekdo chtel tak se regnete pres me dostanete taky 250MB navic stejne jako ja :wink:
https://www.dropbox.com/referrals/NTIxNDI4OTk
nick003
Příspěvek od nick003 »
hi dneska jsou zkusil dropbox a je to opravdu vyborny ale mam problem ze mi nejdou nacist pdf soubory a to ani ty zakladni co byly v dropboxu. Nevite nekdo kde můze bejt problem? dik
GameCenter: nick003
pegancr
Příspěvek od pegancr »
mam dva tipy pro dropbox:
1. aplikace (placena) ifiles umoznuje posilani z iphone na dropbox a zpet.
2. Na strance http://www.gethabilis.com/ si muzete vytvorit emailovou adresu, na kterou kdyz poslete email s prilohou, tak ta se vam ulozi do dropboxu.
Peko00001
Dropbox
Příspěvek od Peko00001 »
Dropbox je sluzba, ktora umoznuje synchronizaciu suborov na viacerych pocitacoch. Je dostupna na vsetkych platformach vratane iphonu a ipadu, cize si mozete priamo prezerat vsetky pdf v dropboxe atd.
Novinkou je aj priamy pristup iphone aplikacie Quick Office k dropboxu, cize mozete Office subory editovat aj mobile :)
Pre synchronizaciu si staci nainstalovat klienta, ktory zosynchronizuje vsetky subory a mate ich stale aktualne na vsetkych PC.
K dropboxu je mozne pristupovat aj cez webove rozhranie z lubovolneho PC, cize mate svoje subory stale pri sebe.
Ako doplnok ponuka dropbox aj historiu suborov a public priecinok s priamou url adresaciou na jednotlive subory.
V ramci dropboxu existuju tri druhy uctov, z toho jeden je zdarma. Poskytuje 2 GB priestoru.
V pripade, ze by ste sa chceli zaregistrovat a pouzijete moj referral link
http://www.dropbox.com/referrals/NTE0NjQ0NzE4OQ
tak to prida vam aj mne 250 MB navyse. Nezabudnite si stiahnut klienta inac to neprida.
Pre starsich uzivatelov uz stara znama vec ale novsim pomôze, tak dufam ze nevadi ze som to sem dal.
Sloučeno do již existujícího vlákna. Chápu tvojí potřebu nahrabat si další prostor přes referral link, ale nezakládej nová vlákna k tématům již probíraným jinde (ano, všiml jsem si že jsi to zařadil do kategorie Aplikace pro PC). ls8
mrzic
Pokud potřebujete přístup do Dropboxu přes WebDAV, je to možné.
viz. viewtopic.php?p=343729#p343729
House_MD
Příspěvek od House_MD »
Možná jsem právě objevil Ameriku, ale Dropbox jde parádně používat jako "cloudové iTunes". Písničky na DB jdou přehrávat v iPhonu, jako kdyby byly v iPod aplikaci... Akorát je třeba rychlý net :-)
DJJonny
Příspěvek od DJJonny »
pocuj mna by zaujimalo ako si pouzil dropbox na hudbu napr. v iphone? pretoze pesnicky tam dam a pustat ich viem po jednej, ale chcel by som vediet ci sa to da vyriesit aj tak ze tam budem mat cele playlisty a budem to mat priamo v ipod prehravaci stale aktualne bez potreby sync cez kabel.
PS: ak Vam nebude vadit aj ja sa pridam s mojim linkom http://db.tt/qE4rA1Y cez ktorý Vy aj ja získate 250mb priestoru navyse a zadarmo (treba stiahnut a nainstalovat po registracii aj klienta a prihlasit sa don, inac to ten bonus neprida). :)
Shwollo
Příspěvek od Shwollo »
existuje nejaká možnosť ako z dropboxu prehrať (stiahnuť) seriál *.avi? Uploadnem si pár častí na DB a potom si ich budem sťahovať do iPhone. Dá sa to?
miro1309
Příspěvek od miro1309 »
Ja to robím cez GoodReader, samotný Dropbox sa mi zdá nemotorný, ale to je vecou názoru. Keď som na wifi sieti, tak GoodReader synchronizujem s Dropboxom a tak mám po ruke všetko, čo potrebujem. Podporuje aj USB sharing.
georgesoft
Re: Dropbox [AppStore] for Iphone 3G
Příspěvek od georgesoft »
Potrebuju pro meho znameho pouzivajiciho Iphone 3G starsi verzi DROPBOXU, ktery nevyzaduje iOS 4.3 (posledni verze pro 3G je 4.2.1).
Podivejte se do iTUNES, jestli nahodou jeste nemate starsi verzi DROPBOXU a poslete mi IPA soubor.
Nebo kde sezenu starsi verzi DROPBOXU? Prosim!!!!
jackherrer
Příspěvek od jackherrer »
pojd na chat, tohle se tady rozebirat nebude
cuting
Příspěvek od cuting »
Předevčirem proběhl update,ktery vyrazně zrychlil nejvice kritizovanou pomalou rychlost streamingu. Konečně se dá na některá videa i koukat. Jinak dnes proběhl i docela zásadní update i dalších aplikaci, zmíním zde jen Vimeo a Skype, obě výrazně k lepšímu.
 Apple hračky 
Příspěvek od Metalgirl »
No, ještě by mohli vylepšit upload. Používám camera upload a nahrát videa na server je fakt někdy o nervy.
cuting
Upload je hlavně o lince. Drtiva většina poskytovatelů buď s uploadem lžou a nebo jej mají děsivě nestabilní. Např UPC. Tam na speedtestu lítá nahoru dolů ,až z toho někdy bolí oči. A když už je někde jakžtakž slušný, tak jsou velmi často problémy i s routerem, a to i doma. O 3G uploadu operatorů raději nemluvě.
 Apple hračky 
Ne upload mám 5 mbit/s a je stabilní. S routerem též není problém. Prostě je pomalý server. I download do PC jde pomalu.
scorpi
Příspěvek od scorpi »
Metalgirl píše:No, ještě by mohli vylepšit upload. Používám camera upload a nahrát videa na server je fakt někdy o nervy.
Já jsem vysledoval, že pokud uploaduju přes aplikaci v iPhone, iPadu nebo z Maca, tak je to přesně jak popisuješ.
Pokud to posílám fotky (mnohdy ve vysokém rozlišení), použiju webové rozhraní a tam to jede rychlostí blesku.
mirmo80
Příspěvek od mirmo80 »
Ale fotky najprv musis preniest do pc/ntb nie? Alebo ti to takto funguje cez safari?
