Jednoduchy jailbreak pre FW 2.1.0
nowzman
Příspěvek od nowzman »
Tak a je to tu. Vysel novy FW a coskoro aj mozno na JB. Takze tu je postup.
1) Jednoducho si stiahnite originalny FW 2.1.0 pre vase zariadenie.
iPodTouch (RS.COM - direct download):
Kód: Vybrat vše
http://rapidshare.com/files/144786423/iPod210.part1.rar
http://rapidshare.com/files/144781957/iPod210.part2.rar
{ostatne doplnim ak niekto da linky}
2) Stiahnite si najnovsi QuickPwn.
QuickPwnRC3.Morphey.Version (RS.COM - direct download):
Kód: Vybrat vše
http://rapidshare.com/files/144779748/QuickPwnRC3.Morphey.Version.rar
3) Zapinte si iTunes, iPod / iPhone, zapojte kabel.
4) Stlacte SHIFT a kliknite na button RESTORE v iTunes. Vyberte si originalny FW a nahrajte ho do zariadenia. FW mozte samozrejme aj updatovat cez Check for updates priamo v iTunes.
5) Vypnite iTunes. Zapnite QuickPwn.
6) Vyberte zariadenie, vyberte znova originalny FW 2.1.0.
7) Pozorne sa riadte instrukciami. Program vam krok po kroku piste co a jak dlho mate stlacit a drzat.
8) Hotovo.
Sp4rh4wk
Re: Jednoduchy jailbreak pre FW 2.1.0
Příspěvek od Sp4rh4wk »
Pekny navod, jen tady uvedu pro nedockavce neco od bigbosse:
"While I posted a series of steps on how to jailbreak 2.1, I recommend strongly that you all hold off. There are many issues that dev team is working through. A jailbreak isn?t quite enough.
Many apps are not yet stable. Categories will not work because we cannot launch one app from another at this time. Cydia is not yet stable. I recommend you wait a day or two still."
AG3NT
Příspěvek od AG3NT »
Originálny firmware 2.1
2.1 iPhone 2G
Kód: Vybrat vše
http://appldnld.apple.com.edgesuite.net/content.info.apple.com/iPhone/061-5202.20080909.gkbEj/iPhone1,1_2.1_5F136_Restore.ipsw
2.1 iPhone 3G
Kód: Vybrat vše
http://appldnld.apple.com.edgesuite.net/content.info.apple.com/iPhone/061-5198.20080909.K3294/iPhone1,2_2.1_5F136_Restore.ipsw
Comic
Příspěvek od Comic »
Ahojte, tak jsem šel do JB FW2.1 dle tohoto postupu, jen s rozdílem, že jsem si nechal iTunes 8 a zatím to šlape vpoho i čeština jede.
více infa v této sekci
Naposledy upravil(a) Comic dne pon zář 15, 2008 10:10 am, celkem upraveno 1 x.
lofounek
Příspěvek od lofounek »
Je mozne pouzit tento navod i pri prechodu z 1.1.4?
iPhone 7 32GB silver
Apple Watch 42mm Sport
iPad Air 32GB
iPad 2 16GB
iPhone 5 32GB white
iPhone 3GS 16GB black
iPhone 2G 8GB
nowzman
Ano.
FeaR-ou
Příspěvek od FeaR-ou »
cau ... mam dotaz.. ten navod je na FW 2.1.0 ale ten quickpwn pise ze je jenom pro 2.0.0 2.0.1 a 2.0.2 .. a ted sem na obrazovce browse firmware (v quickpwn) , vlozil sem tam ten 2.1 ale nic se nedeje.. .
nowzman
s iPodom to islo mne aj kamosovi bez problemov s 2.1. Aj na ich stranke pisu podporu pre 2.1. To v programe je zrejme len zabudnute a neprepisane.
Zack
Příspěvek od Zack »
Takže:
Odzkoušeno na iPod Touch z verze 1.1.4 na 2.1, vše bez problému šlape :wink:
xslide
Příspěvek od xslide »
Komu to jede na 3Géčku?Když tam hodím FW 2.1 tak ho to prvně nevezme, ale když to zkouším tak jo, pak si zvolím že chci cydii a installer, a pak quickpwn spadne.
alien8_Yamma
Příspěvek od alien8_Yamma »
Škoda jen že je to nahrané na rapidu... hrozně špatně se mě zněj stahuje.. nemohl by to nekdo upnout třeba na uloz.to, nebo ulozisko, zloz.cz, atd... ale hlavně ne repidshare :D
nowzman
Skusal si vobec stahovat? Je to direct download!
