Nový fungující návod .. Julek
děkuju za poslání uživateli VLK
HOW TO: Create iTunes Store Account Without Credit Card! PDF Print
WORKS!
Get iTunes Store Account w/o gift card or credit card!
1. Visit: THIS PAGE and click on redeem my code or something like that...
http://www.tunecore.com/freealbum
2. It'll load for a few seconds and display a code...
a) Now if you just want an account from your own country, click "Redeem at iTunes". It'll take you to the iTunes Store and ask you to login... Click "Create new account", enter your personal information and when it asks for credit card type, simply select "None"...
b) If you want a US store account while your in Bahrain - for example - open iTunes, click on iTunes Store, and go to the very bottom of the page... then, under "My store:", select United States... now go to the top of the page and click redeem (at the top of the page on the right, under "Quick Links". Now enter your code from the page above and it will ask you to login... Press "Create new account", enter your personal information and when it asks for credit card type, simply select "None"...
AND THERE YOU HAVE IT
Jak se zaregistrovat do iTunes? Stahování artworků
1.1.1 OOB> 1.0.2>1.1.1>1.1.2>1.1.3>1.1.4>1.1.2 modem 04.04.05_G a bootloader 3.9
iBrickr, AnySim, PACAY, Carneval, iJailbreak, Ziphone... no vyzkoušel jsem prostě skoro všechny možnosti odblokování...
- Administrator
Re: Jak se zaregistrovat do iTunes? Stahování artworků
Dle informaci, navod nefuncni, pokud narazite na jiny navod sem s tim.
