Je to smutne no.
Po 4 rokoch koncia obe aplikacie.
Osobne pouzivam obe, takze teraz hladat alternativu.
Oficial vyjadrenie:
Dear NotifyMe or Bills ~ On your table user:
We're sorry to announce that our apps have been discontinued. We want to thank to all our customers for the support over the last 4 years. We pulled our "NotifyMe" and "Bills ~ On your table" apps from the App Store in March this year. On 25th July 2013, we will also shut down the online and cloud services completely.
All user accounts will be permanently and securely erased
You will not be able to access your data
NotifyMe and Bils ~ On your table apps will be displaying connectivity errors
Synchronization and push notifications will stop working
We suggest you to choose any of the alternative apppcations available on the App Store from different vendors.
We apologize for the inconvenience.
Thank you
PoweryBase team
NotifyMe a Bills koncia
iPhone X space gray 64 GB,
Apple Watch 44mm space gray,
iPhone.cz
iPhone.cz
Re: NotifyMe a Bills koncia
Netusis jestli je nejaka alternativa pro bills? V roce 2011 jsem ji pouzival na ip4s, pak jsem ip nemel a pak uz na appstoru nebyla, doslo mi ze asi skoncili a ted je to po dlouhe dobe koukam oficialni... Bills mi vyhovoval absolutne ve vsem a prozatim jsem nenasel nic co by se tomu rovnalo pritom bych na spravu placeni uctu neco potreboval.. Diky
Tak som vygooglil zatial 3 mozne ako tak nahraditelne alternativy k Bills.
NotifyMe ma po pravde az tak netrapi, takze tu som nehladal
Takze:
BillMinder - 1,79€ (pre iPhone aj iPad)
BillTracker - 1,79€ aj free verzia (iba pre iPhone)
BillClip - free (pre iPhone aj iPad)
Takze:
iPhone.cz
iPhone.cz
Diky moc.. Libil se mi ten BillClip podle vzhledu, tak nejak by mi to vyhovovalo, funkcnost je ale slaba, moc mi nevyhovuje, je to takove nemastne neslane, principielne je to nejak mimo...
Nasel jsem jeste BillAssist - hodne minimalisticky design, ale zatim se tvari docela dobre...
Stejne me ale stve ten Bills..
Vdaka za tip, vyskusam tiez. Uz testujem 3 naraz (BillClip, BillTracker a BillAssist)
Samozrejme Bills bol vynikajuci, mne sa vsak zatial pozdava BillClip, ktory sa aj svojim UI celkom hodi do noveho iOS7, akurat tu strasnu ikonu aplikacie by mohli zmenit
Takze pre mna osobne zatial BillClip jednoznacny favorit.
iPhone.cz
iPhone.cz
