Zdravim vsechny,
Chtel bych se zeptat na jednu vec:
Mam apple tv 2 gen. kde kdyz dam domaci sdileni a pustim si hudbu (nasdili mi to moji itunes knihovnu) tak cca 2-3 pisnicky to hraje a pak se apple tv restartne. (nedelal jsem update a drive mi to slo normalne) fw mam 5.1.1.
Kdyz si poustim hudbu pres iphone/ipad (take tam mam nasdilenou knihovnu) a pustim si to na apple tv pres airplay tak je vse ok.
Nevite cim by to mohlo byt, ze se mi apple tv restartne?
Diky moc za info
						Problem s home sharing hudby
				Electropunker
- Sons of Jailbreak
				buzzfuzz
Re: Problem s home sharing hudby
pozri si stranku firecore a diskusiu, je tam toho plno, je to nejaky bug cache pamete, ma vyst nejaky update. toto je coment od admina:
"Thanks to those who've sent in their bug reports we think we've tracked down what's causing this. We're currently working on a handful of fixes and are planning to have a new update available within the next week or so.
Hang in there!"
"Update:
So we think we've resolved an issue that is specific to the 5.0.2 Apple TV software, that appears with or without any plugins installed. This issue seems to have been there all along, so it's a bit strange to see a number of reports pop up all at the same time.
Nevertheless, if anyone wants to try the fix before we release it to the public please PM me and I will send over the details.
Note: The fix will need to be installed manually, but this is simply a matter of copying a file across using an FTP program like Cyberduck. A few thumbs up with"
Hang in there!"
"Update:
iPhone 5s |  iPad air | aTV 2 jb  | Macmini  |  iMac 27
				Electropunker
- Sons of Jailbreak
Super, diky moc za info. Urcite pockam na ofiko up od FC
				Electropunker
- Sons of Jailbreak
Vyreseno, vcera vysel atv flash black update, ktery tento problem vyresil
