ipod touch a android
ipod touch 8gb
exsistuje uz bootlace aj pre ipod 2gen alebo je iny sposob ako dostat android ?
mefistos
Re: ipod touch a android
kup si android zarizeni.. nechapu na co si kupovat iOS a rvat na to android
ipod touch 8gb
pretoze to chcem skusit...
mefistos
http://www.idroidproject.org/wiki/Status tady mas co a kde funguje
ipod touch 8gb
takze ked su tam verzie pre iPhone 2G a iPhone 3G a iPod Touch 1G takze asi pre ipod touch 2g neni nic...ked som dobre pochopil
mefistos
iDroid
Porting will start when the OpeniBoot port is finished... hotovy to neni musis si pockat
