The SIM card inserted in this iPhone d...oes not appear to by supported.
Only compatible SIM cards from a supported Carrier may by used to activate iPhone insert the SIM card that came with your iPhone or visit a supported Carrier store to receive a replacement SIM card.
a předtím tam byl vodafone a já mám také vodafone a ted nevím co mám dělat dal jsem restore ale pořád mám na obrazovce emergency volaní a obrazek usb kabelu a loga itunes ...
I need help..
