kdysi jsem nainstaloval stufitexpander a od te doby mam ve status baru ikonu magic menu. Manuálně ji po každém restartu ukončuji.
Víte jak se jí zbavit nadobro?
Díky za rady.
Odstraneni Magicmenu ve status baru
oPicka
Re: Odstraneni Magicmenu ve status baru
http://www.cynosurex.com/Forums/Display ... icMenu_2.0
Cannot uninstall your app. completely. It still has control of the menu. Can sometimes get to Spotlight, but only thru keyboard shortcut, and that only sometimes; no mouse click at all for Spotlight. The program itself, except uninstall,worked fine. Just wanted to uninstall and reinstall, to see how friendly the program is. It is not friendly. What files do you modify, how many? There is no file "Info.MagicMenu". Plist files show nothing remains of magicmenu yet it is still in control of menu: ie, menu still hides/finds with mouse. What other files am I not finding? (I do like the program, don't like unfriendly uninstall). OS X is vrs. 10.4.11/PPC/g5.
Michael
Sun, 02 Aug 2009 18:54:25 +0000
Simply uninstalling MagicMenu will not turn off the auto-hide feature. You have to use MagicMenu to turn off the feature for the specific app(s) first. Then uninstall MagicMenu.
