zdravim vsetkych,
prosim o pomoc.
ked dam v disk utility Repair Disk Permissions tak mi vypise toto:
Permissions differ on "usr/share!derby", should by drwxr-xr-x, they are lrwxr-xr-x.
Warning: SUID file "System/Library/CoreServices/RemoteManagement/ARDAgent.app./Contents/MacOS/ARDAgent" has been modified and will not be repaired.
Uz som to dal aj opravit cez Install DVD a stale to pise.
Inac neviem ci to ma s tym nieco spolocne ale ked robim napr. v iMovie tak nabehne farebny kruzok a vsetko to trva velmi dlho.
Vdaka za rady
disk utility - problem
Peko00001
j.v.
Re: disk utility - problem
Klidně hlášení ingnoruj, je to známá chyba a nic neznamená
http://support.apple.com/kb/ts1448
_druhý_ odkaz z googlu, mimochodem
...gone with the wind...
Peko00001
ano prave som to vygooglil. aj tak vdaka za snahu.
aspon vidno ake je toto forum dolezite. Napadlo ma skôr ako google
