Dost se mi libi tento programek, napodobenina z leopard docku.
http://bianki.ovh.org/multistack/#entries
po jeho instalaci to rvalo ze nema prava, tak sem je pres terminal upravit, ted zas pise ze nejde zapnout auto aktivace. uz fakt nevim, poradi nekdo jak uvest tuto aplikaci do funkce.
Stack
jenicekk
Re: Stack
tak sem nasel tenhle navod, vsem to funguje, jen me porad ne. muze to nekdo testnout?
Ok.... here a quick guide in English..
1. Install Stack from Installer then use Cyberduck, Fugu to copy it from iPhone to your mac/pc
2. Now you will have "Stackcontroller.app" on your mac, Extract it we need 2 files in there, stack.app and com.steventroughtonsmith.stack file
3. Next extract stack.app you will see 4 files in there, delete the file icon.png and rename file stackicon.png to icon.png
4. Now, compress stack.zip folder to .app folder and transfer it to your iphone /Application
5. Restart your springboard, then you will see stack icon. Move it to the below-right conner
6. Transfer file com.steventroughtonsmith.stack to /System/Library/LaunchDaemon
7. Respring/ Restart your iphone and stack should work now.
If you want to change the app in stack or icon just like I did, you need to go to /var/root/Library/Preferences then copy file com.steventroughtonsmith.stac.entries to your computer, use textedit to change the program name & icon and that's it.
Hope you can do it.
Cheers,
Hope you can do it.
Cheers,
Julek
- Administrator
Re: Stack
nejsem schopný ti to řict už vím jen že app jsem podle nějakého návodu nacpal do iPhone, ale kde to už fakt nevím .. to bylo loni
tzn fakt dlouho a protože mě to nijak neoslovilo už jsem to dávno vypustil..
