Chcem sa spytat ci nepoznate niaku moznost kustomizacie status baru?
Vytvaranie vlastnych ikoniek a spustanie za urcitych podmienok.
Existuje utilita "Erica Utilities" (pristupna z cydie) a ta obsahuje celkom dobre utility pre terminal.
Jenou z nich je sbar.
Kód: Vybrat vše
iPhone:~ root# sbar
sbar [options]
-l List the available status bar icons and exit
-s icon Set a status bar icon
-r icon Remove a status bar icon
-t icon Check icon for 3 seconds, then remove
Kód: Vybrat vše
iPhone:~ root# sbar -l
0_AirPort 0_Bars 1_AirPort
1_Bars 2_AirPort 2_Bars
3_AirPort 3_Bars 4_Bars
5_Bars Airplane AlarmClock
BG BatteryBG BatteryCharged
BatteryCharging BatteryInsides BatteryLowBG
Bluetooth BluetoothActive BottomCorners
EDGE_ALT_ON EDGE_ON GPRS_ON
HeadsetBatteryBG HeadsetBatteryFill HeadsetLowBatteryFill
Play Plus TTY
UMTS_ON VPN mmsoff
mmson 0_AirPort 0_Bars
1_AirPort 1_Bars 2_AirPort
2_Bars 3_AirPort 3_Bars
4_Bars 5_Bars Airplane
AlarmClock BG BatteryBG
BatteryCharged BatteryCharging BatteryInsides
BatteryLowBG Bluetooth BluetoothActive
HeadsetBatteryBG LockIcon Play
Plus TTY UMTS_ON
VPN
a ak dam napr.
Kód: Vybrat vše
iPhone:~ root# sbar -t VPNtak sa nic nestane, a mozem skusat aj ine vysledok je ten isty.
PS: info o utilite najdete na http://ericasadun.com/ftp/EricaUtilities/
Za odpoved dakujem.
