Zrušit učet na apstore
honza54
Prosím o radu jak zrušit účet na apstore, tedy i data o platební kartě, děkuji, Honza54
PeterKiss
Re: Zrušit učet na apstore
Toto som ešte neskusal ani o tom nepočul.
Kazdo padne napis na support a informuj sa.
Edit : tak som niečo zgooglil Apple to nepodporuje ale co som sa tam docital tak to ľudia riešia nasledovne presnejšie ľudia z UK a USA myslím že sa to dá aj v cz kontach nastaviť platobnú metódu na none.
There's really no official way to cancel an iTunes account because you never get charged unless you buy something. It doesn't cost you anything to keep the account, but if you want to be safe, follow these instructions:
Open iTunes, log in, select "change credit card", and click the radio button next to "none". Now you will have no credit card number on file. That's pretty much the closest thing you can do to cancel an iTunes account.
