registrace itunes
registrace itunes
Prosím o pomoc.Pročetl jsem vše,co šlo ohledně registrace iTunes a nic nefunguje.Prostě pokud nemám kreditku,kterou to vezme,tak nemůžu instalovat ani free aplikace.Zkoušl jsem postupy přes USA a taky nic.Jen zadáním čísla karty.Poradí někdo jak dál?
Re: registrace itunes
tak to ti asi nepojde no, ja mam tiez ten problem...mam normalnu visa kartu a ukaze mi to tam ze debetne karty nie su podporovane. mozno to casom spravia
Dufam, ze vam toto pomoze. Zaregistroval som sa v pohode zo slovenska, bez kreditky s mensim chatom s apple ktory vam sem "pastnem"
? Welcome to iTunes Store Chat!
? Hi, my name is John. How can I be of assistance?
? John: Hi slovakia!
? slovakia: hello
? slovakia: I'd like to ask you about creating account from Slovakia
? slovakia: I've registered but still did not received authorisation email
? slovakia: but I can login with this account into online store for example
? John: I understand. I see that your account has been successfully created.
? John: What message are you receiving when you log in to the iTunes Store?
? slovakia: you have not verified your account
? John: Okay. Give me a moment to look into this for you.
? slovakia: ok, thank you
? John: Concerning the email confirmation, have you checked to make sure that it is not in your SPAM folder?
? slovakia: yes, there is nothing
? John: Okay.
? John: Do you have iTunes open now?
? slovakia: yes
? John: Does it have your account name, or "Sign In" in the upper right hand corner?
? slovakia: "Sign In"
? slovakia: When I use this button and fill all fields I receive message "you have not verified your account"
? John: I see.
? John: Give me a few minutes to look further.
? slovakia: ok, I'll be here
? John: Now try to sign in.
? slovakia: thanks, it works now!
? John: Awesome!
? John: You are set to go.
? slovakia:
thank again, have a nice day!
? John: You're very welcome! You too!
? John: Thank you for chatting with me. Apple values your feedback. Please click the blue "Close" button at top left to answer a few questions about your experience with me today.
? slovakia: hello
? John: Okay.
? slovakia: yes
? John: I see.
? John: Awesome!
? slovakia:
ale to jsi mi nepomohl.Já tam nemůžu zadat číslo kreditky , protože to nebere a žádný email , tak jako tobě mi nepřijde.
Kde se dá chatovat s applem?
Rád bych s nima vyřešil problém s kreditní kartou....
Almi: citát zmazaný. ak odpovedáš na predošlý príspevok, citát nepoužívaj.
Napriklad tu.. dole je ikonka chat:
http://www.apple.com/support/itunes/store/password/
do ověřovací otázky zadej how old i am ? a odpoved i am 21..pak ti pude se regnout
Nazdárek, dá se teda iTunes nějak zaregistrovat bez zadání čísla karty?
Mi to připadá jako dost omezené chtít po lidech číslo karty. Pokud si budu chtít něco koupit tak si to koupím a při té platbě bych to tam zadala ale proč to chcou hned u registrace to fakt nechápu... Prosím poradíte mi někdo?
Poradíme. Zkus si něco o tom přečíst, jsou toho tady popsány tuny. scorpi
