Muze to nekdo prelozit Diky
Until work on the iPhone OS 3.1 (currently in Beta) is complete and the Cupertino-based company can release the update, Apple has decided to take a stab at one pretty annoying problem the iPhone OS 3.0 brought: the incapacity to use WiFi or Bluetooth on the iPhone or iPod Touch. There are several symptoms attached to this issue:
1. No WiFi or Bluetooth address is listed.
2. You seem to be connected to the web via WiFi, but you cannot browse the web, check your email, or send data over WiFi.
3. The iPhone is not able to pair with your Bluetooth device or accessory.
4. You cannot see any values or entries for IP Address, Subnet Mask, Router, or DNS appear when you tap Settings -> Wi-Fi -> the arrow icon next to the network.
The following products are affected: iPhone, iPod touch, iPhone 3G, iPod touch (2nd generation).
?This can happen if, during the initial setup of the iPhone or iPod touch or after performing a software update or restore using iTunes, no Wi-Fi or Bluetooth address was registered,? explained Apple. To resolve the issue you must sync your device to iTunes and backup all you info; then you must use one of the workaround presented below:
1. Settings -> General -> Reset -> Reset Network Settings
The WiFi or Bluetooth address should be listed now in Settings -> General -> About -> Wi-Fi Address or Bluetooth. Still not working for you? Try the next step then.
2. Settings -> General -> Reset -> Erase All Content and Settings
3. Restore the device?s software using iTunes -> sync all your previous settings -> check to see whether the WiFi or Bluetooth address is displayed (Settings -> General -> About -> Wi-Fi Address or Bluetooth). Still not working for you? Try the next step then.
4. You tried all the steps presented above and none of them work? There may be a problem with the device itself, problem that you cannot solve yourself. You may need to take it in for repairs. See this Apple Support article for details.
In related news, Apple recently announced that the iPhone 3G S may be affected by overheating issues. There are certain situations that might trigger the Temperature warning message to appear. Like for example if you leave your iPhone in your car, it is a hot day, and the sunlight hits your car directly. Or when you leave your iPhone exposed to direct sunlight for large amounts of time. Even if you are in a shaded location, using resource-hungry apps on a hot day for a longer period of time might trigger the warning message as well.
What you should do, as advised by Apple, is use the device in places where the temperature is between 32? to 95? F or 0? and 35? C and store the device in places where the temperature is between -4? to 113? F or -20? and 45?. Keep in mind that using the device in very low or very high temperatures may cause the iPhone 3G S to stop functioning or may shorten battery life.
Apple Tackles iPhone and iPod Touch WiFi and Bluetooth Issue
Lukáš Petr
Re: Apple Tackles iPhone and iPod Touch WiFi and Bluetooth Issue
Hele to je moc textu, sice tomu rozumim, ale psat to fakt nebudu. Zkus pouzit Google Translator.
iPhone 6S 64GB fw. 5.0.1
crafted by Glimsoft.com
dodulo
Do práce na iPhone OS 3.1 (v súčasnosti vo verzii beta) je úplný a Cupertino-založená spoločnosť môže uvoľniť aktualizácia Apple sa rozhodla prijať stab jeden docela otravný problém s iPhone OS 3.0 priniesol: neschopnosti použiť WiFi alebo Bluetooth na iPhone alebo iPod Touch. Existuje niekoľko príznakov pripojené k tejto otázke:
1. No WiFi alebo Bluetooth adresy sú uvedené.
2. Zdá sa, že ste pripojení k webu cez WiFi, ale nemôžete prechádzať web, skontrolovať e-maily alebo posielať dáta cez WiFi.
3. Na iPhone nie je schopný dvojicu s vaším Bluetooth zariadenia alebo príslušenstvo.
4. Vy nevidíte žiadne hodnoty alebo údaje pre IP adresa, Maska podsiete, router alebo DNS objaví keď tuknete Nastavenia -> Wi-Fi -> na šípku vedľa ikony na sieti.
Nasledujúce produkty sú ovplyvnené: iPhone, iPod dotyk, iPhone 3G, iPod dotyk (2. generácie).
"To sa môže stať, ak sa počas počiatočného nastavenia pre iPhone alebo iPod dotyk alebo po vykonaní aktualizácie softvéru alebo obnoviť pomocou iTunes, bez Wi-Fi alebo Bluetooth adresa bola zaregistrovaná," uviedol Apple. Ak chcete vyriešiť tento problém, musíte synchronizáciu vášho prístroja na iTunes a zálohovanie všetkých vás info, potom musíte použiť jeden z workaround uvedené nižšie:
1. Nastavenia -> Všeobecné -> Reset -> Nastavenie siete Reset
WiFi alebo Bluetooth adresa by mala byť uvedená hneď v Nastavenia -> Všeobecné -> O -> Wi-Fi alebo Bluetooth Adresa. Stále ešte pracuje pre teba? Skúste ďalší krok ďalej.
2. Nastavenia -> Všeobecné -> Reset -> Vymazať všetok obsah a všetky nastavenia
3. Obnoviť zariadenia pomocou software iTunes -> synch všetky vaše predchádzajúce nastavenia -> skontrolujte, či je WiFi alebo Bluetooth adresa je zobrazená (Nastavenia -> Všeobecné -> O -> Wi-Fi alebo Bluetooth Adresa). Stále ešte pracuje pre teba? Skúste ďalší krok ďalej.
4. Skúšali ste všetky kroky vyššie a žiadny z nich pracuje? Môže byť problém s prístrojom sám, problém, ktorý nemôžete vyriešiť sami. Možno budete musieť vziať za opravu. Pozri tento článok Apple Podpora podrobnosti.
V súvisiace novinky, Apple nedávno oznámil, že iPhone 3G S môže byť ovplyvnený prehriatia otázky. Sú určité situácie, ktoré by mohli vyvolať teploty, ktoré sa zobrazí varovné hlásenie. Ako napríklad keď necháte váš iPhone v aute, to je horúci deň, a na slnečnom svetle hity vášho automobilu priamo. Alebo keď necháte váš iPhone vystavená priamemu slnečnému svitu pre veľké množstvo času. Dokonca aj keď ste v vystínovaných umiestnenie, použitie zdrojov-hlad apps na horúci deň na dlhšiu dobu, by mohla spôsobiť varovné správy rovnako.
Čo by ste mali urobiť, jak radí Apple, je použitie prístroja v miestach, kde je teplota medzi 32 ° až 95 ° F alebo 0 ? a 35 ? C a uložte prístroj v miestach, kde sa teplota pohybuje v rozmedzí -4 ° až 113 ° F alebo -20 ° a 45 ?. Majte na pamäti, že používanie zariadení vo veľmi nízkych alebo veľmi vysokých teplotách môže spôsobiť, že iPhone 3G S prestať fungovať alebo môžu skrátiť životnosť batérie.
