Aplikace na fotografie - hledám
Je prosím nějaká aplikace, která by umožnila zobrazit u fotografie detaily, jako datum, čas, apod?
Je smutné, že takovou základní věc interní aplikace neumí.
Re: Aplikace na fotografie - hledám
[itunes=435368159]V App Store je aplikace PhotosInfo, ktera by to mela umet, ale zminuji ji hlavne z toho duvodu, ze momentalne je v App Store jeji verze pro iPad ve sleve z $4,99 na FREE a vypada moc povedene:
https://itunes.apple.com/us/app/photosi ... 68159?mt=8[/itunes]
napr. iPhoto
https://itunes.apple.com/sk/app/iphoto/id497786065?mt=8
[itunes=497786065]iPhoto is a universal app that runs on iPad 2 (and later), iPhone 4 (and later) and iPod touch (4th generation and later).
With iPhoto for iOS, Apple brings Multi-Touch to photography in a breakthrough way. Browse, edit and share your photos from your iPad, iPhone or iPod touch, like never before — all the powerful tools you need are at your fingertips. And with iCloud, you can share your experiences as stunning photo journals.
Smart browsing
• Use simple gestures to quickly sort through dozens or even hundreds of photos
• Automatically find similar photos, so you can quickly make comparisons
• View multiple photos side by side to help you choose your best images
• Tap to flag any photo, apply a descriptive tag or mark it as a favourite
• Resize and reposition scrollable thumbnail grid for optimal browsing in either orientation
Multi-Touch editing
• Simply touch and drag on the parts of the image you want to change
• Use the face-aware Crop tool to keep your friends and family in the picture whenever you change the aspect ratio
• Touch and drag on the image to adjust blue skies, greenery and warmth
• Drag the white balance loupe to make precise colour corrections
• All image adjustments are completely non-destructive and can be modified at any time
• Straighten your pictures with a tap using automatic horizon detection
Brushes
• Use your fingertip to paint photo adjustments just where you need them
• Turn on edge detection to help you apply adjustments with even more precision
• Lighten, darken and change saturation or sharpness selectively
• Paint out spots and blemishes with a powerful Repair brush
• Brush away red-eye, or use the Soften brush to minimise wrinkles
Professional-quality effects
• Enhance your photos with dozens of beautiful, Apple-designed effects
• Give your photos a hand-sketched or painted look with new ink effects
• Touch and drag to add drama to landscapes with a selection of graduated filters
• Create a perfectly toned black-and-white photo by simply dragging your finger
• Pinch and zoom a vignette or tilt-shift filter to focus on a key part of the photo
• Apply artistic effects to transform your photos into brilliant watercolours
Photo journals
• Share your stories in a whole new way as beautiful photo journals
• iPhoto automatically flows your pictures into a great-looking layout that’s fun to personalise
• Freely move and resize photos with a touch of your finger
• Touch and drag to add captions, maps, dates, and even the weather
• Publish your photo journals to iCloud as stunning web pages
• Share links to your journals directly to Facebook or Twitter, and via Messages
Other great iPhoto features
• iPhoto is a universal app, optimised for iPhone, iPad and iPod touch
• Contextual coaching tips are available on all devices
• Edit high-resolution photos — up to 36.5 megapixels — on certain devices
• Share photos directly to Cards, iMovie and other compatible iOS apps
• Create cinematic slideshows of your photos with a few taps
• Post your photos directly to Facebook with your own comments, locations and friend tags
• Beam photos between your iPhone, iPad and iPod touch, including all non-destructive adjustments
• Use AirPlay to stream photos and slideshows to your HDTV over Wi-Fi with Apple TV
• Print your photos wirelessly on an AirPrint-enabled printer
Some features require an iCloud account and/or compatible Internet access.
AirPrint requires an AirPrint-compatible wireless printer.
AirPlay is compatible with the second-generation Apple TV or later.[/itunes]
Smart browsing
Multi-Touch editing
Brushes
Photo journals
Supr, díky za to iphoto.
Sice 4,45€ ale stojí to za to! Co zamrzí, tak chybí podpora ip5, ale snad bude brzo aktualizace.
Edit: tak po zakoupení mi to hned nabídlo aktualizaci a teď už je to i pro ip5.
- Sons of Jailbreak
Dzanek nevidim cez tapatalk ci mas JB, ale existuje tweak Photo Info , máš tam -cas
-datum
-original velkost foto
-priecinok kde je dana foto ulozena
-velkost kB
-model fotaku
-clonu
-cas atd atd
-datum
-velkost kB
-model fotaku
-clonu
-cas atd atd
iPhone 8 plus 256GB
Nedalo mi to a dnes jsem udělal jailbreak, právě kvůli doplňkům, které v ios chybi.
Ten Photo info je plně dostačující, ani jsem nemusel včera iphoto kupovat
- Sons of Jailbreak
Skoda, iPhoto je objemna appka,... funkcie ma take iste ako bezne lacnejsie appky..
Niekde na fore som videl navod, ako ziskat spat peniaze zo zlej kupi.. mal si tam nejake moznosti omylom si klikol na kupit, nevyhovuje atd atd tak skus si to pohladat a pripadne to vypln cez iTunes ,.. mozno motyka vystreli a peniaze vratia...
iPhone 8 plus 256GB
hladam nejaku app na fotenie s i5 ktora by mi pri foteni ponukla cas a datum ktory by sa zobrazoval na vyfotenej fotografii. App bez JB ... existuje take nieco? som uprimne nazlosteny na fotak resp. jeho zakladnu app i5 ktory taketo funkcie nevie poskytnut
- Sons of Jailbreak
Cila skús Camera Reporter, môžeš si zap/vyp údaje ktoré sa majú zobraziť na fotke,..
iPhone 8 plus 256GB
Dakujem ...
Sent from CiLA iPhone
