BUZZ player
Teedok
BUZZ player [AppStore $0.99]
Příspěvek od Teedok »
BUZZ player
BUZZ Player is a multimedia player supporting many audio and video codecs and file formats, and various streaming protocols.
Zobrazit video na http://youtu.be/cklVk_tT5tE
Kód do fóra: [youtube]cklVk_tT5tE[/youtube]
AppStore: $0.99
:arrow: BUZZ Player can play almost anything, including:
? Container formats: 3GP, AVI, ASF, FLV, MKV (Matroska), MOV (QuickTime), MP4, NUT, Ogg, OGM, RealMedia, Bink, WMV
? Video formats: Cinepak, DV, H.263, H.264/MPEG-4 AVC, HuffYUV, Indeo, MJPEG, MPEG-1, MPEG-2, MPEG-4 Part 2, RealVideo, Sorenson, Theora, WMV, Bink
? Audio formats: AAC, AC3, ALAC, AMR, DTS, FLAC, Intel Music Coder, Monkey's Audio, MP3, Musepack, RealAudio, Shorten, Speex, Vorbis, WMA, Bink
? Subtitle formats: SRT, A*S, SSA, SUB, MSI and EMBEDDED Subtitle
? Protocols: RTP, RTSP, HTTP, FTP, MMS, Netstream (mpst://), SMB, ffmpeg://
BUZZ Player also has Built-in Network Browser allows user to play and copy files from Widows/Mac/Linux PC and remote FTP servers. (SMB & FTP Support).
User may call BUZZ Player to play media files from external application such as mail, readers...
Update: 1.2
Support uPnP Media Server. User can browse Media Server in home network to play and copy media files.
? Add "Stream Index Selection" feature, that allow user to select desired stream when play multi stream media.
? Add "Remember Playing Position" feature, that remember playing position at stop time and seek to this position automatically in the next play time.
? Add "Audio Balance" feature, that allow user to adjust volume of Left and Right audio channels.
? Add "Adjust subtitle timing offset" feature that allow user to adjust subtitle timing to desired position.
? Add "Skip Frame" feature to allow to play large video file.
? Improve video quality when play video (VOB file).
? Fix bug when display subtitle (Arabic).
:arrow: Možnost nahrávání a stahování do telefonu po internetu
:arrow: Po nahrání souboru(Hot Tube Machine) do telefonu a vytvoření složky(NEW). Soubory jde také stahovat.
:arrow: Vytváření složek přímo v telefonu
:arrow: Spojení s počítačem
:arrow: Nastavení
Program je skvělej, výborně se ovládá a má hodně využitelnejch funkcí. Rozhodně doporučuju :)
Teedok
Naposledy upravil(a) Teedok dne pon lis 01, 2010 3:17 pm, celkem upraveno 2 x.
Pavuk
Re: BUZZ player
Příspěvek od Pavuk »
Daju sa manuálne naťahať filmy cez WinSCP do fonu a potom odtial sledovať cez tento program? Abych to nemusel ťahať cez dáta - mam iba 1GB na mesiac
Jan12
Re: BUZZ player
Příspěvek od Jan12 »
ako mám s ním začať,podrobnejší návod,prosím
Re: BUZZ player
naco navod?
podla hodnoteni na appstore, je skoda sa nim zaoberat
Teedok
BUZZ player
Ano jde přetáhnout filmy z PC do telefonu. Např přes winscp nebo i-fun box.
Program je velice jednoduchý řekl bych že na ovládání a jeho funkce přijdeš hned.
Mě velice vyhovuje. Můžu odkudkoliv dát filmy do telefonu, nebo si je naopak stáhnout a nepotřebuju k tomu ssh nebo něco podobného. Podpora titulků a spousty formatůn je taky skvělá takže jen a jen doporučuju;)
nalevka
BUZZ player
Příspěvek od nalevka »
To je neco jako air video ne? Co je lepsi?
Jan12
Re: BUZZ player
s PC viem pridať filmy,prehrá všetko,ale neviem pridať adresy URL
MiGR
Re: BUZZ player
Příspěvek od MiGR »
Mne docela zaujalo ze umi tolik formatu ze je bude umet prehrat i z UPnP. V teto cenove kategorii je to dost ojedinele. Znate jiny player, ktery to umi?
Teedok
BUZZ player
Air video je spíše na přehrávání filmů na PC, filmy to při přenosu konvertuje... Hlavní výhoda BUZZ playeru je podpora mnoha formátů jak audio tak video.. Nemusíte řešit co si do telefonu dáváte protože z 99% to player přehraje. Navíc má možnost vytváření vlastních playlistů.
Toto je první přehrávač který jsem viděl který dokaže tolik formátů;)
dunihlav
Re: BUZZ player
Příspěvek od dunihlav »
Za chvilku vynde zadarmo VLC player... ;-) netreba investovat do takovéto či podobné aplikace penízky.
Celý vesmír si z nás dělá srandu. ;-)
georgesoft
Re: BUZZ player
Příspěvek od georgesoft »
Teedok
BUZZ player
Jenže pro přidání videí do VLC potřebuješ iTunes. Pri přidání videí do BUZZ player nepotřebuješ ani SSH.
Teedok
pegancr
Re: BUZZ player
Příspěvek od pegancr »
Kdo s JB dneska potrebuje itunes. Normalne jsem hodil film do vlc/documents, tak jako u cehokoliv jineho.
Ale VLC neumi titulky, Buzz jede v pohode? ty pismenka s hackami vypadaji nejak deformovane.
update: tak jsem ten Buzz koupil a je podle mne ze vsech ctyr prehravacu nejlepsi. Titulky po zmene na verdena 18 naprosto v pohode a ve srovnani s oplayer (ten jediny umi take titulky ok) je plynulejsi.
Re: BUZZ player
Kupil som BUZZ Player HD (pre iPad). Mierne som to skusal a tu su nejake postrehy:
1. browsuje to SMB, co je dobre pre majitelov NAS :-) ale: nezapamata si to vlozeny ucet a heslo, takze sa zaheslujete pri kazdom otvoreni network browseru (v podstate zakazdym!!!)
2. network browser je trochu nemotorny, nemozem si ani na uvodnu stranku odlozit nejaky shortcut na oblubenu zlozku aby som ju mal hned dostupnu
3. mkv v hd, aj 720p neprehra ani po sieti ani ked si to nakopirujem do ipadu. Parada je, ze to zobrazi obraz ale seka to nepozeratelne.
4. titulky - vyborna podpora.
5. raz za cas spadne :-)
Zhrnute na zaver: ak ste uz davno v ere HD mkv, tak je to skoro k nicomu. SD filmy v pohode pozerate, ziadny problem.
Podobne prehravace uz existuju a viacmenej ani jeden nie je dokonaly.
Teedok
BUZZ player
Mě se hlavně líbí skvělá podpora titulků:).. Teď jsem tam zkusil dát mkv a skutečně se na to nedá koukat :(... ale na iPhonu nepotřebuji full HD. Takže se spokojím s méně kvalitními formáty:)
Teedok
Re: BUZZ player
AK MAS FILMOTEKU :-) v HD, TAK AKO TO BUDES RIESIT? :-) konvertovanim? to mozem rovno ist na m4v
Moonlight
Re: BUZZ player
Příspěvek od Moonlight »
Potreboval by som poradit.
Kupil som Buzz player a som s nim velmi spokojny.Filmy ktore ked prehravam normalne v iphone idu bez problemov na celej obrazovke ,ale ked pripojim iPhone k TV cez AV composite kabel tak obraz je orezany,obraz ide na celej obrazovke ale chyba mu akoby 1/4 z pravej casti.
V nastaveniach som vsetko skusil ale nic nepomaha.Viete mi poradit ako tento problem vyriesit?
new iPad wifi 32gb
iPad wifi 3G 32gb
iPhone4 32gb
iPhone 3GS 16gb
iPhone 3G 8gb
iPhone 2g
sidlas
BUZZ player
Příspěvek od sidlas »
Koukal sem hodinu a pul na film a mam 18% baterky v haji to se mi treba u air video live nestalo ale oba programy funguji trochu jinak kolik vam to zere bazerky?
Teedok
BUZZ player
Mě to vezme tak kolem 8% při jednom dílu Simpsonů.
Teedok
Re: BUZZ player
Nová verze (1.2)
ke stažení v AppStore
Teedok
McDog
Re: BUZZ player [AppStore $0.99]
Příspěvek od McDog »
No ja ked si tam pustim na mojom 3G nieco,tak mam iba cierny obraz a zvuk mi ide....uz som skusal styri avicka a nic
Vitezslav2
Příspěvek od Vitezslav2 »
Mě to na iPhone 4 přehrává bez obrazu.Nebo spíš se špatným obrazem.
iPhone XS Max 256GB
iPad 2019 32GB WIFI
Apple Watch Series 5 Nike+ 44mm
Teedok
Mě to teda jede v pohodě a musim uznat že s updatem se teda vytáhli :) Pamatování poslední přehrávané scény, možnost nastavení kanálu audio Streamu, přidání/ubrání ms u titulek...
Téměř nic mi už nechybí, je to krása ;)
Teedok
Příspěvek od ls8 »
Jak vypadají české titulky? V prvních příspěvcích byly znaky s českou diakritikou jinak velké a tučné proti ostatním znakům. Jak to vypadá v posledních verzích?
Teedok
Měl jsen je špatně uložené (v ANSI). Stačí změnit kódování na UTF-8 a jsou v pořádku :)
Příspěvek od ls8 »
Takze titulky se museji prekonvertovat? To je skoda, treba Oplayer umi zpracovat titulky v jakemkoliv kodovani. Jinak se mi tahle aplikace libi.
dubak
Re:
Příspěvek od dubak »
Smazana citace, viz pravidla! Julek
ked pustis film treba ich len prestavit, aspon ja ked som nastavil pri prehravani kodovanie na Windows Latin 2 tak isla aj diakritika
BlazingUFO
Příspěvek od BlazingUFO »
neviem prist na to ako presunut video do priecinku, neviete mi s tym niekto poradit?
GameCenter - BlazingUFO
Teedok
To v telefonu bohužel nejde. Musíš to udělat na PC nebo si vytvořit PlayList a tam to jde přidat i v telefonu:)
Teedok
Re: Re:
Příspěvek od ls8 »
dubak píše:ked pustis film treba ich len prestavit, aspon ja ked som nastavil pri prehravani kodovanie na Windows Latin 2 tak isla aj diakritika
Kde se v Buzz playeru nastavuje kódování titulků?
dubak
Re: Re:
Necituj předchozí příspěvek, citace smazána. MG
ked pustis film a spustis si ten ovladaci panel tak ked tuknes na tu ikonku TXT tak tam, aspon na ipade ju mam, neviem ci je to tak aj na iphone
Příspěvek od ls8 »
Je to tak, diky.
Petr1
Příspěvek od Petr1 »
je to skvělej přehrávač, opravdu
tolik formátů ... a těch titulků :) ... jen to prostředí mohlo bejt hezčí :D ... ale tam jsem jen 5sec a pak si zapnu film :)
Omlouvám se,za trapné dotazy nebo příspěvky,prosím :), mějte se mnou strpení !?
Co vím, napovím.
Co nevím, vymyslím !
ASUS G55V|WIN7
JackieTran
Příspěvek od JackieTran »
Pouzivam VLC a Buzz zaroven,jelikoz vlc se seka pri prehravani videa s koncovkou *mov.
Buzz je skvely.A jen tak mimochodem autor je z vietnamu ( jsem hrdy za to :mrgreen: )
Petr1
ty máš filmy i s koncovkou mov ? já mám filmy jen v AVI, MPEG a nebo FLV ...
a MOV ti přehraje iPod nebo ne ? :)
není to zbytečnost mít tolik aplikací ? :-O ... já nevím jen se ptám telefon mi někdy příjde spomalenej vždycky když si ho ráno zapnu a pak zapnu aplikace bo tak ...
Co vím, napovím.
ASUS G55V|WIN7
pepol
Příspěvek od pepol »
Může mi někdo poradit,kam ten film do iP přetáhnout??Do jaké složky?
Petr1
Filmy do něj hodíš přes DiskAid .. touto cesou: "private/var/mobile/Applications/BUZZ Player" ... ¨
pro iTunes musíš film převést do formátu ".mp4" nebo třeba ".mov". Umí to například "FreeVideoToiPhoneConverter". Ale pokud máš BUZZ Player, tak si myslím, že je uplně zbytečné cokoli převádět ještě navíc když umí krásně i titulky
Co vím, napovím.
ASUS G55V|WIN7
Moonlight
V iTunes zvolis tvoj iPhone-pojdes na aplikacie(v iPhone) a zrolujes v tom okne dole,tam najdes Buzz(nie v zozname aplikacii ale pod nim) a tam to len jednoducho pretiahnes.
new iPad wifi 32gb
iPad wifi 3G 32gb
iPhone4 32gb
iPhone 3GS 16gb
iPhone 3G 8gb
iPhone 2g
Harrison
Re: Re:
Příspěvek od Harrison »
dubak píše:ked pustis film a spustis si ten ovladaci panel tak ked tuknes na tu ikonku TXT tak tam, aspon na ipade ju mam, neviem ci je to tak aj na iphone
Ano kodovanie sa da tymto sposobom pekne zmenit, ALE aplikacia si ho nevie zapamatat :evil: Vzdy ked prehravac spustim, musim nanovo nastavit kodovanie titulkov, co je dost neprakticke. O tom, ze si prehravac nepamata posledny prehravany film, ani nehovorim. Ale snad sa dockame nejakeho updatu, ktory tieto veci vyriesi...
    iPhone HW: iPhone2G(8GB), iPhone3G(8GB), iPhone5S (32GB), iPhone6 (64GB)
    Mac HW: MacBook Pro Retina (late 2013, 8GB, 256GB SSD)
    Ostatne: Apple Watch 1st gen., AppleTV 4th gen., Airport Extreme
Příspěvek od ls8 »
Hlavně aby autor zapracoval na kvalitě obrazu, a zejména plunylosti přehrávaného videa. Co se týče výbavy funkcemi, nemá Buzz Player konkurenci, ale přehrávané video často zadrhává, při přeskakování v čase ztráci synchronizaci zvuku.
