New: PushGmail (APP Store)
caran
Příspěvek od caran »
Dnes vysla táto zaujímavá App aj ked nie su prvy ale urcite zaujmu cenou.
Testovane. Funguje bez problemov.
Viac info tu: http://www.PushGmailApp.com
Category: Utilities
Price: $0.99 (iTunes)
Description:
Lowest priced Gmail app available! NO SUBSCRIPTIONS REQUIRED!!!
Beta testers have described PushGmail as even faster than desktop Gmail.
View FAQ at http://www.PushGmailApp.com
Get instant, reliable push Gmail on your iPhone or iPod Touch. Unlike
other apps, PushGmail gives you the option to access your Gmail in the
Mail app or within PushGmail.
You might be thinking, why would I want to access my Gmail within
PushGmail anyway? Here's why:
PushGmail notifies you of all new incoming Gmail in 3 ways - badge,
sound and text alert. This means when you receive a new email, you
will be able to view the message immediately. Once the PushGmail app
has been opened, your notifications will reset.
PushGmail works with all Gmail accounts including Google Enterprise
and Google Apps email accounts.
PushGmail
iPhone 3G 8GB 3.1.2 TMSK
MacBook PRO 13", 2,26GHz, 2GB RAM
MacBook White, 2,13GHz, 4GB RAM
May Way - FingerPiano
BlazingUFO
Re: New: PushGmail (APP Store)
Příspěvek od BlazingUFO »
mi to pise error registering with push server...
GameCenter - BlazingUFO
brco
Příspěvek od brco »
Podla obrazkov v App Store dokaze hadzat notifikacie aj na zamknutu obrazovku? Caran, mozes mi to potvrdit?
BB Passport
MacBook 12"
BlazingUFO
Ano dokaze, ale nekupuj si tu, nie je iste ze ti to bude fungovat
milan2022
Příspěvek od milan2022 »
urcite nedoporucujem kupovat tuto app mam som ju hned ako vysla chvilu fungovala ale uz dlhu dobu nefunguje,autori sa nato asi vykaslali.
Doporucujem Push For Gmail
http://itunes.apple.com/us/app/push-for ... 29704?mt=8
BlazingUFO
Nadhera, tak som vyhodil 1.59? za nic...
Neda sa vratit nejak ta app? :D
Mrsel
Příspěvek od Mrsel »
Doporučuju překontrolovat push notifikace s free aplikaci z appstoru jmenem:
iPusher
BlazingUFO
mojim push notifikaciam nic nie je, vsetky ostatne app funguju, v pushgmail ich ani nejde zapnut, ked zadam email a heslo a dam activate napise error registering push server
Deraspoth
Příspěvek od Deraspoth »
Taky mi to nefunguje a nikdy mi to nefungovalo...zbytečně vyhozený peníze....radeji jsem koupil push for Gmail a je to paradní-funguje bezva....
BlazingUFO
Ja napisem mail do applu alebo co, nemozem predsa platit za nieco co nefunguje, 1.59 to som mohol mat radsej pivo, nech mi pekne poslu nas5 peniaze...
Příspěvek od ls8 »
Push notifikace umi oficialni Google aplikace, ktera je zdarma!
BlazingUFO
ale zobrazuje iba cislo pri ikonke, ziadny zvuk, ziadna notifikacia na lockscreene... kupil som si push for gmail a spokojnost... len este musim nejak vymyslet ako sa domoct svojich penazi s5...
