iPhone Web Interface for ?Torrent
Now with support for ?Torrent 1.8 and WebUI v0.350
Here is a very simple iPhone optimized web interface ? it allows for basic control of the ?Torrent client (ver. 1.7.5), you can:
* See the status of active torrents
* Pause, resume a torrent
* Add a new torrent by entering a url to torrent
(or mininova id)
Right now that is all you can do but i'm hoping to add more features.
Installation
To install the ?Phone UI first download and install the ?Torrent webui. Instructions can be found here http://utorrent.cz/help/setup.php.
Now download this zip http://www.davidraso.com/utorrent-iphone/uphone.zip, extract it, inside there is a folder called 'iphone' take that folder and place it inside the webui.zip that you installed in at '%AppData%\uTorrent' on your PC. Don't extract the webui zip just add the iphone folder to it.
Next on your iphone go to the url of your ?Torrent webui adding /iphone/i.html (ie http://192.168.0.3:25673/gui/iphone/i.html), enter your username / password you should now see all your torrents.
Enjoy.
Disclaimer
I created this on a lazy saturday afternoon in a hour ? so it is by no means QA'd there are a few bugs when calculating the size of torrents and sorting, but it works.
Email me if you have any comments or questions
Zkoušel jsem , ale po zadání mojí IP adresy se mi rozhraní v iPhone nenačte...
