carrier loga ios5
carrier loga ios5
prisiel uz niekto na to ako ich zmenit? podla navodu pre ios4 mi to zial nefunguje a sklamal ma aj google
GameCenter - BlazingUFO
Re: carrier loga ios5
To change the carrier logos (manually), you just need to modify the files in your carrier bundle, and then add the "@2x" suffix at the end of the file name.
For example, my carrier is Bell. I have the following files in the Bell carrier bundle:
So I replaced them with the following:
After replacing the images, toggle your phone in Airplane mode briefly (wait till you see your carrier disappear from the preference list). When you reconnect to your carrier, the new images will be displayed (no need for a reboot or a respring; they are not cached).
I can't speak for WinterBoard or anything from Cydia (I theme manually). This works for me on an iPhone 4 (GSM) on iOS 5GM.
funguje, dik
Slo by to nejak popsat strucne v cz? Diky
iPad 4 - 64GB, white, iOS 8.1
iPhone 5S - 64GB, gold, iOS 8.1
appleTV 3th gen.
appleTV 3th gen.
Poradil by mi někdo, jaký program použít, abych se dostal do iPhone? Děkuji
Nainstalujte Total Commander a doplněk T-PoT.wfx !!!
\\\T-PoT\System\Library\Carrier Bundles\iPhone\ ....vyberte svého operátora a nahraďte originální logo.......restart a hotovo
Funkční na iPhone 4 iOS 5.0.1 operator Vodafone
http://www.uloz.to/12092456/logo-ihacker-rar
http://www.ulozto.cz/12121444/logo-vodafone-rar
http://www.ulozto.cz/12234674/logo-t-mobile-ios-5-rar
Default_CARRIER_VF CZ_1only_@2x
FSO_CARRIER_VF CZ_1only_@2x
TS_CARRIER_VF CZ_1only_@2x
T-Mobile CZ
O2-CZ
Pro jiné operátory nutno přejmenovat na svého operátora jen červeně označené !!!
ak vam to pomoze, tak teraz som si zmenil svoje logo operatora na iphone 4 fw5.0.1 z T-Mobile na svoj upraveny znak ( nie nazov ) z rozmermy 62x62. Trvalo mi to 2 mesiace a ziadne rady z netu nefungovali. Az dnes konecne a to asi preto lebo nazvy tych troch obrazkov ( log ) sa nezhoduju s nazvami, co su napisane v subore "carrier.list" . Takze tie obrazky ( loga ) sa musia volat ( v mojom pripade ) a musite dodrzat velke a male pismena
Lenze v pc sa musia premenovat bez koncoveho .png a akonahle tie subory date do
System/Library/CarrierBundles/Iphone/T-Mobile_sk , tak tu priponu .png si priradi sam.
Ja som to robil tiez aj s tou priponou a v mobile sa mi potom zdvojila .png.png .
No a subore "carrier.list" to musi vyzerat takto :
<string>Default_CARRIER_T-Mobile SK_1only_.png</string>
<key>FullScreenOpaqueImage</key>
<string>FSO_CARRIER_T-Mobile SK_1only_.png</string>
<key>StatusBarCarrierName</key>
<string>T-Mobile SK</string>
<key>TransparentShadowedImage</key>
<string>TS_CARRIER_T-Mobile SK_1only_.png</string>
</dict>
<dict>
<key>AllowPrefixMatching</key>
<true/>
<key>CarrierName</key>
<string>t-mobile</string>
<key>DefaultImage</key>
Je to niekde v strede suboru. Mne to fakt funguje.
</dict>
<dict>
<true/>
koncovku si to nepriradi sam, len ty v PC nevidis ze uz ju tam raz mas. zapni si v pc 'zobrazit priponu znamim suborom"a uvidis ze to uz tam raz mas.
NAS Synology DS-111 2Tb
ok, ale hlavne, ze to funguje
- Sons of Jailbreak
dungeon píše:
\\\T-PoT\System\Library\Carrier Bundles\iPhone\ ....vyberte svého operátora a nahraďte originální logo.......restart a hotovo![]()
T-Mobile CZ
O2-CZ
Ahoj,prosim te jak jsi udelal ten cover flow efekt ikon v docku na ios5,diky moc
mne to podla Tvojho navodu neslo, neviem preco.
zastiaľ to nejde ani mne, ale asi budem potrebovať carier bundle pre operátora funfon, resp. jeho kód site. 231-0x? nevie niekto, čo treba zmeniť?
EDIT 21.1.2012:
Problém vyriešený, pracuje to perfektne, MNC siete nepotrebujete pre funfon a iných virtuálnych operátorov meniť, spoľahlivo funguje na 231-01 (orange) 231-02 (Telekom) v adresárovej štruktúre tak ako je uvedené vyššie. Len som musel nechať carier.plist tak ako bol (pre ostatných: neupravovať .plist vôbec ponechať tak ako je. Ja som ho najprv upravoval pre názvy súborov *_@2x.png a tak to nešlo).
Pre stiahnutie: pravé tlačítko a uložiť odkaz ako...
EDIT 21.1.2012:
Dlhodobý užívateľ HTC s androidom,
Nový užívateľ iPhone4.
- Sons of Jailbreak
ako na slovenske O2, ktore nie je v defaultnych priecinkoch? lebo na iOS4 je navod ako na to, len na iOS5 to nefunguje
MacBook Pro late 2010
iPhone SE 128GB
iPhone SE 128GB
2 dungeon : zajímalo by mě to samé co Šmejkyho...
Díky
Díky
Grave D. a Šmejky: jedna se o tweak ze Cydie s nazvem Overflow
iPhone 5S 64GB, fw 8.1
iPad air 3G 32GB, fw 8.1
iPad Mini Retina 3G 32GB, fw 7.2.1 JB
MacBook Pro 13"
MacBook Pro 13"
carrier loga ios5
Tweak zo cydie Zeppelin vie meniť logá!!ja mám slovenskú vlajku,ale je tam toho strašne veľa!!
PC:Win8.1 Pro,Iphone 3G IOS 4.1.2,iPhone 4S 16gb IOS 9.2.3,iPhone 5S 16 GB iOS ,9.3.3,iPhone 6S 64GB iOS 9.3.3,iPad 2 16gb Wifi ios 9.2.3
Mne to aj tak nejde nahradil som všekty skúšal om aj z aj bez koncovky @2x.png ale tále mám hore T-Mobile SK neviete poradiť ale ked om to nahodil bez @2x tak mi ostalo T-Mobile všade okrem notifikačného centra tam som mal voje ale inde nie
Default_CARRIER_nazev operatora-v-levem-hornim-rohu_1only_@2x
FSO_CARRIER_TO-SAME_1only_@2x
TS_CARRIER_TO-SAME_1only_@2x
Nebo co nechápeš?
Nebo co nechápeš?
H_E_C_K_E_R píše:Mne to aj tak nejde nahradil som všekty skúšal om aj z aj bez koncovky @2x.png ale tále mám hore T-Mobile SK neviete poradiť ale ked om to nahodil bez @2x tak mi ostalo T-Mobile všade okrem notifikačného centra tam som mal voje ale inde nie
Stahni si Tweak Zeppelin a hod si tam to logo jaky chces.. je to nejjednodussi volba...
navod na vlozeni vlastnich log http://macthemes.net/forum/viewtopic.php?id=16811776
carrier loga ios5
Na iOS 5 je potreba drobna uprava, rozepisoval jsem to tady (funguje, pouzivam) viewtopic.php?t=32437#p501083
iMac 27" 5k Retina, 4,0 GHz, Core i7, 24 GB RAM
MacBook 12", 256 GB SSD
Apple Watch Sport, 42mm
iPhone 6s Plus, 64 GB
Můžete mi prosím poradit jsk si vytvořit vlastni logo operátora?Přes Zeppelin si to umim upravit, jen nevím jak ve Photoshopu upravit obrázek.Z google si stáhnu nějský obrázek, ale ten se mi vždy uloží tak že je na bílém čtverci.Potřebuji ten daný obrázek nějak dostat z toho bílého pozadí.Prostě ho vyříznout.
Tady přikládám obr. který potřebuji upravit.
AppleTV 2nd geniOS 5.0.1AppleTV4tvOS 10.2.2
iPhone 11 Pro black 64GBiOS 13.1.3
iPad AIR 2 64GB Wi-Fi+4GiPadOS 13.1.3
ABAB, musí to být PNG s transparentním pozadím, ale u takhle malého obrázku by to byl asi dost problém upravit a ještě velká piplačka, aby k něčemu vypadalo, nejlépe je sehnat co největší obrázek a odebrat pozadí, třeba v photoshopu, nebo hledat rovnou PNG bez pozadí.
No já právě v tom photoshopu neumim odebrat pozadí.Prosťe nevím jak.Pokud mám jiný png bez pozadí, tak nevím jak v tom photoshopu tam dostat ten text.
carrier loga ios5
V tvojom prípade asi najskôr polygonové laso.
____________
Moje zariadenia:
____________
Moje zariadenia:
V tom photoshopu jsem fakt uplný začátečník.Trochu podrobňeji.Děkuji
to je nástroj, kde si označíš část, a tu pak vymažeš, že vznikne prázdné pozadí, ale pokud o tom nemáš šajn, těžko se to vysvětluje, ovšem ten obrázek co tam máš půjde velmi těžko a i kdyby se to nějak povedlo, bude vypadat blbě, nejlépe to jde, když jsou ostré hrany a tam se část "ztrácí", jako podklad pro vytvoření PNG s prázdným pozadím je to prakticky nepoužitelné..
tohle .. by asi šlo použít
ale to asi není graficky to pravé
To:cczero
Už mám logo apple s pruhledným pozadím.Dokázal by jsi tym dát ten text.
ABAB, jestli myslíš ten nápis Telefonica ..tak uměl, ale musel bych mít ten font, což bohužel nemám a ani mě nenapadá, kde ho sehnat ... předpokládám, že to nebude nějaký veřejný, či free, ale jejich speciálně navržené logo
ale pošli to jabko .... nebo spíš, upni ho někam .. a já něco zkusím ..
viz ..
zkus to tam zkušebně nacpat, co to udělá?
viz ..
Tak tady je odkaz http://findicons.com/icon/207296/apple?width=32
Velikost by pak měla být 40x40 a 20x20
Je to podle Zeppeling loga. Díval jsem se do iFile.
Bylo by fajn kdyby se ti to povedlo.
podívám se na to, ale já logo kopíruju přímo, bez programu do systému a velikost je na výšku vždy 40, a to logo tam je ve třech souborech a délka může být, myslím, že i 150 ..
Zkus to s uvidíme jak to bude vypadat.
ABAB, zkus tam dát tohle, jak to bude vypadat ...
No vypadá to zajímavě. také jsem se pokoušel o nějaká výtvory. Myslíš, že dokážeš změnit tu Telefonica na stejnou barvu?
Pokusím se, ale pak to úplne splyne s tím o2, a uz ji to tam měl jako logo? Zajímal by mě screen...
Ono když je to v jedné barvě tak to pak ve status baru vypadá lépe.
Já jsem to dělal přes photoshop a pak nakopíroval přes iFile do Zeppelin.
Jen neumím tu barvu změnit. Kde tu barvu měníš ty?
Uřčitě tady dám pak nějaké obrázky.
- Sons of Jailbreak
O2 sk funguje po odistalovani commcentre patchu, ktory som podozrieval za vypadavanie signalu.
takze priecinok som vytvoril podla navodu pre 4.0 a tam som kopiroval loga, jedine ktore mi teda chyba je to, ktore sa ma zobrazovat v notification centre...
iPhone SE 128GB
iPhone SE 128GB
Já logo operátora dělám přes Zeppelin. Přes Winspc si zkopíruji do PC jakékoliv logo z Zeppelin. V Photoshop si vytvořím vlastní logo. To pak přejmenuji na koncovky
a vložím zpět do iPhone
- Sons of Jailbreak
len ja som chcel na O2 loga O2, ked som v narodnom roamingu T-mobile a ked som v Macedonsku na expedicii tak potrebujem vidiet, ci som naroamingovany na normalnu siet, alebo na satelitnu, v ktorej ma sms stoji mnoho eur
iPhone SE 128GB
iPhone SE 128GB
- iPhoneHolik
carrier loga ios5
ABAB píše:Ono když je to v jedné barvě tak to pak ve status baru vypadá lépe.
Znas cestu k Zeppelin? Nemuzu ho v iFile najit... Diky
Ahoj tay je
Library/Zeppelin
Library/Zeppelin
