Status bar a pocasie
cluzoe
Příspěvek od cluzoe »
stiahol som si s Cydie weathericon...
ALE hadze to furt hlasku ze please open cydia and install libstatusbar
no ale take nieco v cydii nieje
Takze predsa je!
Per FARBOD21 in another post:
It's in Cydia, bigbossrepo, but you won't see it unless you go into manage>>settings>> and choose developer (not user or hacker).
“Only the Dead Have Seen The End of War”
Platon
mike_15
Re: Status bar a pocasie
Příspěvek od mike_15 »
je to v cydii ale musis ju zapnut ako developer (zapnes cydiu, das manage a hore mas settings, tam tapne na posledne Developer) nechas naciat cydiu a das hladat libstatusbar :)
