iFile aplikacia na prehliadanie suborov (doc, pdf, jpg, mp3)
dodo_mt
Příspěvek od dodo_mt »
Tak dnes sa objavila v Cydii aj dalsia sikovna aplikacia a to na prehliadanie suborov vo vasom iPhone. Subory sa do iPhone nahravaju cez webovy prehliadac do ktoreho zadate adresu ktoru vam "vygeneruje" aplikacia iFile potom uz len jednoducho kopirujete subory medzi PC a iPhone. V podstate vam staci len internetovy prehliadac a wifi.
Aplikacia dokaze prehravat mp3 subory (skusal som priamo z kniznice iTunes), otvarat dokumenty a prehliadat ich (vyskusal som Word) otvarat a zobrazovat obrazky (.jpg, .png) otvarat pdf subory vsetko som este nevyskusal tak neviem. :)
Viac info tu:
Instructions:
1.You can use iFile to move files from computer(Windows,Mac,Linux) to your iPhone/iTouch with WIFI.
2.You don't need to install any software on your computer,just open your web browser and you can manage the files which on your iPhone/iTouch.
3.You can upload files in any format to your iPhone/iTouch or download files from your iPhone/iTouch by using a web browser.Another view,iFile makes your iPhone/iTouch to a memory disk.
4.You can create a directory in your iphone/itouch.
5.You can open the most of the file formats. Ifile can support Japanese and Chinese files.
supported formats
audio:mp3,wav
image:jpg/jpeg,png,gif,bmp,tif/tiff and the formated supported by iPhone/iTouch
video:mov,mp4,m4v,3gp
document:doc,ppt,xsl,pdf,htm/html,safari ArchivePage,plain text(txt,c/c++,perl,java...).
6.Consider the security,iFile can close its sharing,so you can't access any files by using a computer.
7.When you close a file, iFile can remember the last position. Next time you open the file, it will be opened from the last position.
8.iFile supports the automatic screen rotation,and also allows you to turn off the automatic screen rotation.
9.You can zoom pictures or documents by multi-touch.
HINT:
1.If the path of the file you want to upload contains Chinese characters,you'd better to use the firefox or safari browser.
2.Open a pdf format is faster than opening a doc format when these two formats have the same content.
iFile Instructions
Step1:Make your IPhone or ITouch connect to a WiFi network.
Step2:Open the iFile and you will see the server ip displayed at the bottom of the screen.
Step3:Open a browser on a computer which in the same LAN, then enter the server ip in the address blank and open this link,your will see the upload page opened.
Step4:You can choose the file which you want to upload,then upload it,after uploading,you will see the file displayed on your IPhone.And you can touch the file to open it on you IPhone.
Step5:You can also delete the file.
A nejake obrazky:
dodo
Apple Keyboard (Wireless)
Apple Magic Mouse
fuckp
Re: iFile aplikacia na prehliadanie suborov (doc, pdf, jpg, mp3)
Příspěvek od fuckp »
Vypada zajimave, ale stejne asi zustanu u ReaddleDocs...Da se tam jednoduse nastavit iPhone jako nove misto v siti a pak staci zkopirovat jakykoli soubor a prohlizet. Sice neprehrava mp3, ale to mi vubec nevadi ;)
Yreg
Příspěvek od Yreg »
Z môjho pohľadu je to AirSharing zadarmo. Alebo to dokáže niečo viac?
trpaslikcz
Příspěvek od trpaslikcz »
Ahoj chci se zeptat, kam nahrát soubory aby mi je přehrála i jiná aplikace co mam v telefně? Existuje nějaká složka do které to v telefnu můžu přesouvat a aplikace do ní budou šahat? Nechci být odkázán jen na to, že si budu moci soubory prohlížet jen přes tuto aplikaci.
Příhlad, v telefonu mam aplikaci "Documents" (prohlížení souborů office), kam mam přes ifile, do jaké složky, nahrát soubor *.xls abych ho mohl v této aplikaci otevřít a editovat?
EDIT: už sem to našel, ale stejně je to zdlouhové. Soubor se nahraje do /var a pak se musí přesouvat do příslušných složek. Pro přesun fotografií a videa je určitě lepší použít iTunes
Todleje dobré akorád tak pro přenos souborů z jednoho kompu do druhého a ani tak to není nejlepší varianta :-D
Naposledy upravil(a) trpaslikcz dne pát bře 27, 2009 2:21 pm, celkem upraveno 1 x.
pajcer
Příspěvek od pajcer »
ja som ju tiez skusal a isla aj hned prec - nic zvlastne neobsahovala. A nefungovalo mi mazanie a presuvanie suborov (predpokladam ze nedostatocnymi pravami - toto mi inak robia viacere aplikacie podobneho zamerania, napr. MobileFiles - neviete ako ich nastavit, nastavenie prav na 7777 nepomohlo)
M32online
Příspěvek od M32online »
aplikacia funguje skvele, mazanie suborov bezproblemov, pdf, word vsetko krasne funguje, jedine co chyba je zmena prav k suborom....
pajcer
FAKT :D
po reinstalacii funguje vsetko skvele .... iba ikonka bola trocha rozhasena, ale to som si uz sam upravil...
BlazingUFO
Příspěvek od BlazingUFO »
je mozne stahovat dokumenty (pdf,doc,txt...) priamo z internetu, ked totiz v safari kliknem na nejaky dokument, tak mi ho priamo v safari otvori a safari download plugin funguje len s medialnymi subormi
edit: ja ked sa pokusim otvorit jednu 9MB prezentaciu tak mi to skoro okamzite padne, ale furt lepsie jaki docs, ktore mi padne skor nez ju otvori
GameCenter - BlazingUFO
S474N
Příspěvek od S474N »
dodo_mt píše:Subory sa do iPhone nahravaju cez webovy prehliadac do ktoreho zadate adresu ktoru vam "vygeneruje" aplikacia iFile potom uz len jednoducho kopirujete subory medzi PC a iPhone. V podstate vam staci len internetovy prehliadac a wifi.
Trosicku nevyhoda, ze ten program rovnou nezjisti IP a nevypise ji. Clovek to potom musi vypnout, podivat se na aktualni "liznutou" IP a znova spustit. Nebo jsem neprisel na nejaky figl?
citrixman
Příspěvek od citrixman »
Vie mi niekto poradiť ako z mailu v iphone dostanem prílohu do iFile?
iphone XS Max 256 GB iOS 12.1.3 beta 3
Carabei
Příspěvek od Carabei »
S474N: a to ve spodní liště programu není ip adresa?
MacBook Pro Retina 15 10.10
iPhone 6 8.1.2, Etymotic hf5
iPad mini Retina 32GB 8.1.2
pajcer
citrixman píše:Vie mi niekto poradiť ako z mailu v iphone dostanem prílohu do iFile?
musis mat mat nainstalovany plugin pre Mail aplikaciu na ukladanie priloh, ktore potom normlane najdes v suboroch pomocou iFile...
vola sa to: attachmentSaver (v cydii, ale je platena)
citrixman
to pajcer:vdaka.vsetko funguje.
dwick
Příspěvek od dwick »
Ted jsem zjistil super vec. Mezi dvema iPhony (zkouseno na iP4 a 3G) se pres iFile daji posilat libovolne soubory pres bluetooth :) Objevil jsem jsem Ameriku :lol:
Life sucks. And then you die.
risix
Příspěvek od risix »
zdravím , existuje nějaká aplikace na prohlížení +úpravu výše zmíněných dokumentů přímo v telefonu bez použití iTunes a PC ?
Kubec19
Příspěvek od Kubec19 »
Caute taka trosku "lame" otazka daju sa v ifile premenovavat subory?
BlazingUFO
ano, tapnes na taku tu modru sipocku a otvoria sa ti vlastnosti, tam mas moznost zmenit nazov
Kubec19
Dajú sa do ifilu pridávať veci z Camera rollu?
Příspěvek od Metalgirl »
Přes iFile se do složky camera rollu dostaneš, tam si pak můžeš otevírat obrázky, videa na přehrávání. Je to v /private/var/mobile/media/DCIM
Kubec19
Jáj diks vôbec ma to nenapadlo :D
TomXasS
Příspěvek od TomXasS »
Mam s nim problem. Chcem upravit Cydia.list a vypise mi :"COCOA ERROR (513)". Cim to moze byt ?
Kubec19
Mas ho oficialne kupeny?
TomXasS
Mam. Akurat citam, ze to je problem s licenciou ci co, nechapem.
stikyworld
Příspěvek od stikyworld »
Lze posílat soubory i na jiné BT zařízení? Nebo jen z iPhone na iPhone ?
dwick
pomoci iFile lze pouze iPhone<->iPhone
Renik
Příspěvek od Renik »
UPDATE:
1.5.0-2 - Bugfix Release
- Fixed issue that if a folder iFile starts with did not exist, iFile showed the spinning wheel forever.
- Fixed crash when transferring a file from iFile to iFile (sender crashes).
- Fixed bug that when a user chose select all, iFile did not enable the toolbar buttons.
- Fixed crash when tapping on folder in search results of hierarchical search.
- Fixed crash when choosing a viewer for a file without known type for 4th time.
- Fixed that opening files in iFile via URL ifile:/// did not work anymore. This was a problem in context with Attachment Saver and Safari Download Manager.
- Slowed down animation when moving through tabs in tab chooser (cover flow).
- Enabled antialiasing in tab chooser (cover flow).
iPhone X 256GB Space Gray
Apple TV 4 64GB
Už vyšla další verze 1.5.0-3, ve které se měly opravit další bugy.
Gekko gecko
Příspěvek od Gekko gecko »
Aplikace vypada ajn jen dva dotazy po synch se data ukladaji kam do others ze jo?
Druha je aplikace placena neo free abych kvuli tomu nedelal zbytene JB neustale ppoovani kabelu je otrava a pres wii by to bylo lepsi :wink:
iPhone 5S 16GB Silver iOS 9.2
Aplikace je placená. Stojí $4.99 (myslím). Vlastně ti umožní přístup do celé adresářové struktury iPhonu, iPodu, iPadu. Kam se co ukládá, to fakt nemám tušení a neřeším to. Hlavní pro mě je, že si hodím na dropbox textové dokumenty, cokoliv a následně si to v iFile otevřu, v čem chci. Potom také přes iFile upravuji plisty, pokud potřebuji něco změnit v iDevice.
Vulgi
Příspěvek od Vulgi »
funguje aj na ios 5.0.1??
muso
Příspěvek od muso »
jo
ABAB
Příspěvek od ABAB »
Ahoj zkoušeli jste s někdo připojit přes iFile k Time Capsule?
Jde mi o to abych si v iFile najel třeba do AVPlayer a film si poslat do Time Capsule.
Děkuji
iPhone 11 Pro black 64GBiOS 13.1.3
iPad AIR 2 64GB Wi-Fi+4GiPadOS 13.1.3
barca
Re: Evasi0n - untethered Jailbreak iOS 7 – 7.0.4
Příspěvek od barca »
ahojte, neviem, ci si niekto kupil oficialne iFile zo Cydie, ale je som tak urobil predvcerom a pise sa tam, ze to ma integrovane attachmentsaver a bluetooth. Neviete, ako sa to spusta ? Bluetooth som skusal, ale ako keby sa to chcelo pripojit len k iphonu, ipodu a ipadu.
Naposledy upravil(a) Metalgirl dne čtv led 02, 2014 11:16 pm, celkem upraveno 1 x.
Důvod: Přesunuto sem.
PeterKiss
Příspěvek od PeterKiss »
Ved tam mas manual a je aj cesky a slovensky :-)
barca
tam som to nenasiel
kosostvorcek
Příspěvek od kosostvorcek »
funguje niekomu priamy upload suborov z ifile na ucet do dropboxu?
