Redsn0w iOS6 Beta Tethered JB!
Kony.cz
Příspěvek od Kony.cz »
Tak to jsem necekal ze to bude tak rychly :))))
Just like at the at the wind-down of last year’s WWDC, we’re releasing a developer-only version of a redsn0w tethered jailbreak for app developers. The following limera1n-able devices are supported:
iPod touch 4G
iPhone3GS
iPhone4 (GSM)
iPhone4 (CDMA)
UNLOCKERS AND THOSE PRESERVING THEIR UNLOCKABLE BASEBANDS SHOULD STAY FAR AWAY FROM THIS! You will very likely lose your unlockable baseband if you try to install iOS 6.
THIS JAILBREAK IS INTENDED ONLY FOR DEVELOPERS OF JAILBROKEN APPS! There are just too many broken components (Apple’s official apps, 3rd-party App Store apps, Cydia apps, etc) for this to be useful to anyone but those truly looking to fix bugs in their iOS 6 jailbroken apps.
CYDIA WILL NOT BE INSTALLED because it just hasn’t had time to be updated to the new SDK. The only access you’ll get to the device is through SSH or afc2. If you don’t know what either of those are, you shouldn’t be using this developer version of redsn0w!
THIS REDSN0W WILL NOT HACTIVATE! You need to be an iOS developer with a registered UDID to get past the activation screens. PLEASE DON’T PIRATE APPLE SOFTWARE! Only registered devs with Macs can develop iOS applications,and only those people will have legitimate access to the beta IPSWs.
THIS IS A TETHERED JAILBREAK ONLY! No new exploits are being exposed with this jailbreak (it uses geohot’s limera1n bootrom exploit), but that comes at a cost. You will need to use redsn0w to “Just boot” button to be able to use many things, including Cydia and Safari. If you see a white icon for Cydia, or if Cydia or Safari crash when you open them, it’s because you didn’t boot tethered.
You must point redsn0w at your IPSW the first time you “Jailbreak” and “Just boot” tethered because that IPSW is only available to developers, and redsn0w can’t automatically fetch the pieces it needs from it.
OS X
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_mac_0.9.13dev1.zip?attredirects=0&d=1
WIN
https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.13dev1.zip?attredirects=0&d=1
via http://blog.iphone-dev.org/redsn0w-iOS6
[*]iPhone SE 16 GB Gold
[*]iPhone 6 16 GB White
[*]iPhone X 64 GB Black
Marek
Re: Redsn0w iOS6 Beta Tethered JB!
Příspěvek od Marek »
Po obede testujem a dam vediet co a ako
EDIT: Tak už je iPhone jailbreaknutý, ale je to iba SSH, cydia ešte nie je pre iOS 6 pripravená.
EDIT 2: Tak jailbreak ide až do doby kým vyjde cydia preč
MacBook Air
Magic Mouse
iPhone 5
francesca
Příspěvek od francesca »
APPLE MacBook CZ white unibody spring 2010/ C2D 2.4GHz/ 13.3" 1280x800/ 8GB RAM/ GF 320M/ 250GB 5.4k/ DVD/ WF/ BT/ CAM/ MAC OS Maverics
iMessage: vecne.zamilovana[at]gmail.com
Mihac
Příspěvek od Mihac »
Tak to je hodně dobrý.
Jen jestli na to Apple nečeká, aby to nějak bloknul ve FINAL verzi.
jiriczek
Příspěvek od jiriczek »
Taky jsi myslím, že je tam ta chyba záměrně... Aby jsme si to užily v betách a na ostro už to udělá na 110% :)
Mac Pro - 512 GB SSD - Windows 10
iPhone 6S - 16 GB
iPad 2 - 16 GB
technologics
Příspěvek od technologics »
tak dneska som si dal ios 6 musim povedat ze je to dost velka zmena oproti 5.0.1, mam uz aj jb cez redsnow a stale fici citelne rychlesie ako ta 5, nahodena aj cydia a este dalsich par veci si dam a uvidim ako to pojde
FW 4.3.4 --> 5.0.1 JB --> 5.1.1 --> 6.0.0 beta 1 JB :D --> 6.0.0 beta 2
Marek
Cydia v pohode funguje? A hlavne SBSettings, a Activator, nevieš?
MacBook Air
Magic Mouse
iPhone 5
musashi
Příspěvek od musashi »
Taky by me zajimalo. Mel jsem iOS6 nahozeno, ale vratil jsem se zpet na iOS5, pze mi chybel JB a jeho aplikace. Kdyby tyhle zakladni veci fungovaly (a treba LockInfo k tomu), tak bych zase rad zkusil nahodit ... :)
iPhone 7 128GB Black
iPad Air 2 64GB
Apple TV 4 32GB
Apple Thunderbolt Cinema 27"
Arcane
Příspěvek od Arcane »
žádná záměrná chyba tam neni, máte to napsaný i v popisku od autora. Využívá to stále stejný limera1n exploit od gehota už někdy od iOS4 a je to s JBkem furt stejné v jakékoliv betě
technologics
cydia zatial funguje v poho, len jedine co som si vsimol je ze sa tam nezobrazuje ten popis, iba ten zakladny sa tam zobrazi
sbs settings nejde cize ani activator a nejde ani nc settings
chcete este nieco vediet ci ide?
Freaders
Příspěvek od Freaders »
jestli někdo má JBK mohli by jste mi vyextrahovat retina tapetu?
iPhone SE 64GB Space Gray
Moto 360
Xiaomi Mi Band
iPhone 5C 32GB Blue
iPhone 4S 8.1.3
makatch
Příspěvek od makatch »
Mám nainštalovanú betu3,spravil som jailbreak,nainštaloval Cydiu,no tá sa nespustí len preblikne.Ako ste na tom vy ?
iPhone6+,64GB,iOS 9beta3
TomXasS
Příspěvek od TomXasS »
Skuste niekto, ci fakci "NoVoiceMail" z cydie ... Ja mam 4S a nato JB nie je.
Gylly
iOS 6 Jailbreak s Redsn0w - Jen iPhone 3GS, 4 a iPod Touch 4
Příspěvek od Gylly »
Ahoj, našel jsem návod, jak udělat jailbreak přes Redsn0w na iOS 6 s iPhone 3GS, 4 a iPod Touch 4G s následnou instalací Cydie přes počítač. Zkoušel to tu už někdo? Kdyžtak se pochlubte jak jste dopadli. ;)
http://absinthejailbreak.org/jailbreak- ... s-redsnow/
[mod=BEAVERS]Nedávej odkazy do code, u nás je to posuzováno jako porušení pravidel, která jsi evidentně nečetl. Tím se vystavuješ nebezpečí dalšího postihu.[/mod]
______________________________________
iPhone 6 | black | 16GB | iOS 9.3
genius7
Re: iOS 6 Jailbreak s Redsn0w - Jen iPhone 3GS, 4 a iPod Tou
Příspěvek od genius7 »
ahoj. ja som to skusal hned v den vydania iOS 6 na svojom iPhone 4 a vsetko (aj ta Cydia) funguje bez problemov. Cely postup bol naozaj velmi jednoduchy.
Příspěvek od Metalgirl »
Jo, včera provedeno na 3GS, funguje. Ale bacha, ne všechny app ze cydie jsou ještě kompatibilní s iOS 6, jejich instalace může způsobovat problémy.
benitoSVK
Příspěvek od benitoSVK »
Tu je zoznam zatiaľ funkčných(updatovaných) app http://jailbreakiphone4s5.com/the-most- ... ort-ios-6/
Gylly
Metalgirl píše:Jo, včera provedeno na 3GS, funguje. Ale bacha, ne všechny app ze cydie jsou ještě kompatibilní s iOS 6, jejich instalace může způsobovat problémy.
Super. A prosímtě, nevíš, jestli tam jede i ultrasn0w unlock? 05.13.04? Dík ;))
Tak to vůbec netuším, sama mám totiž neblokovaný iPhone od výroby.
Gylly
No nic, Jdu to vyzkoušet. Vím na 100% že to nepojede.. ale co. :'D
Marky1980
Příspěvek od Marky1980 »
Untethered?
Marek
Untethered nie, iba tethered. Untethered len na prvých iPhonoch 3Gs so starým bootloadrom
MacBook Air
Magic Mouse
iPhone 5
jajinus
Příspěvek od jajinus »
mam otazku iTools mi nenasel device tak jsem stahl [zakázáno] a dodrzel jsem postup ale pri zadani konecne adresy mi to napsalo ze stranka nebyla nalezena tak jsem opakoval postup znovu a pri zadani hesla mi to ukazalo spatne heslo a pritom jsem tam napsal alpine co s tim?diky
Udělej to přes putty, funguje.
cczero
Příspěvek od cczero »
tady http://www.ijailbreak.com/cydia/ios-6-c ... lity-list/ je trochu rozsáhlejší a ucelenější seznam funkčích JB věcí, ale ty pro mě zásadní, zatím bohužel nic ..
kunec
Příspěvek od kunec »
To co jsme potreboval zatím bohužel nefunguje
Sbsetings i sbprofiles hází telefon do Save módu. Nezbývá než počkat na aktualizace.
Navíc, vždycky dávám iPhone na noc na nabijecku. Dnes rano ale Topol jako blázen. Nevím zadali za to muže JB, nebo se mi po letech odporu cela baterka. Dal jsem hned restore a uvidím co bude dal.
Taky tady http://spravodaj.madaj.net/ HD
bodmrazu
Příspěvek od bodmrazu »
Já jsem na tom stejně, nainstaloval jsem Cydii a jen problikne. :( Netuší někdo co s tím?
kunec
po nainstalování cydie se iP restartne, tudíž ho musíte znovu nabootuvat...
ve Redsn0w Extracts a Joust boot
Marku activator funguje, ale sbsetings hází iP do Save mode
Mě sbsettings házely do safe modu jen v případě, že jsem klikla na ikonu processes, jinak přepínače fungují bez toho, aniž by mi to dělalo problém.
kunec
mně to hází ještě Letový režim, ostatní se zdají být v pohodě
ananas
Příspěvek od ananas »
OT: uz by sa to mohlo presunut z noviniek do jailbreaku
Marek
OT: vytvoria sa este sekcie, a potom sa poprace
MacBook Air
Magic Mouse
iPhone 5
TomXasS
No este nie je ani poriadny JB tak necakajte ze vam pojdu hned vsetky tweaky.
jajinus
Metalgirl píše:Udělej to přes putty, funguje.
Tak jsem to zkousel pres ten putty a da se rict ze mi to napsalo ze byl zjisten malware a ve finale mi to napsalo ze moji IP zarazila druha strana takze se tam ani nedostanu.Nevite nekdo jak jinak do tel dostat cydii?pls uz jsem z toho na vetev dekuju za rady
Stáhla jsem putty přímo z oficiálních stránek, žádný malware mi to nehlásí, nejspíš poplašná zpráva ze strany antiviru, vypni ho na tu dobu. Přes putty to jde jednoduše. Putty jsem stáhla odsud http://www.chiark.greenend.org.uk/~sgta ... nload.html
kunec
já s putty taky neměl problém
bodmrazu
Tak já nevím. Ať dělám co dělám Cydia jen blikne, zkoušel jsem už asi všechno. Není někdo z Prahy kdo by byl ochoten za nějakou úplatu pomoci?
Kony.cz
kdyz ti Cydia jenom problikne tak musis iP uplne vypnout... zapnout posledni verzi Resn0w a v extras dat boot joust..... potom ti ten Redsn0w ten iP zapne a nastartuje ve specialnim rezimu, je to kvuli tomu ze JB je porad jeste tethered..
bodmrazu
To já vím, nedělám to poprvé. Ale bohužel pořád ne a ne naskočit. Používám redsn0w_win_0.9.13dev4. Cydia ukazuje i 5x aktualizaci, ale nespustí se. :(
steinj
Příspěvek od steinj »
Mám úplně stejnej problém cydia jen problikne a spadne. Zkusil jsem i obnovit udělat JB znova a pořád stejný.
