Pages - zkratky??
Alwer
Pages - zkratky??
Potreboval bych poradit ohledne Pages v iPadu, koupil jsem si apple wireless keyboard, vsechni vpohode, maximalni spokojenost az na jednu "malickost", ktera je pro me celkem dulezita.
Jestli je nejaka zkratka, kdyz oznacim nejaky text, na podtrzeni/tučný font? - jak je treba u PC ve Wordu zkratka tusim Control (nebo Alt) + B pro tucne pismo a nebo + U pro podtrzeni.
Tohle mi hodne chybi, nikde jsem to nenasel.diky
Re: Pages - zkratky??
myslim, ze nie su.
Julek
- Administrator
nejdou namapovat ?
Nie nejdu.
Alwer
Diky. A nevite jestli v nejakem jinem textovem editoru tyhle zkratky funguji?
Nie som si tu celkom isty, ci VIE iPad prijimat kombinacie stlacenych klaves z externej klavesnice.
Klavesove skratky:
In Pages:
Cmd + A = select all
Cmd + C = copy
Cmd + V = paste
Cmd + X = cut
Shift + arrow = select as much as you need from a paragraph of text
Cmd + Z = undo
Shift + Cmd + Z = redo
Cmd + Up/Down = moves the cursor to the top/bottom of a document
Apple Keyboard Shortcuts that don?t work on iPad:
Cmd + B ? you?d expect it to bold your selected text, but it doesn?t. For formatting text you need to use the virtual keyboard.
Cmd + Tab ? you?d expect it to switch between applications. However, iPad is not a multitasking device, so there are no applications to switch between, thus the shortcut does nothing. For starting a new application you?d need to press the Home key, then launch your application from there.
Double space ? if you use the virtual iPad keyboard, this command would generate a full stop and a space, plus the next letter you?ll type will be in caps. This is not working on either the iPad keyboard dock or on the wireless Apple keyboard connected to the iPad.
Klavesove skratky:
In Pages:
Cmd + C = copy
Cmd + V = paste
Cmd + X = cut
Cmd + Z = undo
Alwer
Výše jmenované - Cmd + Z, X, C, V atd. jdou bez problému.
Doufám že do budoucna bude např. to Cmd + B možné, ale moc v to nedoufám.
milan0301
chtěl bych se zeptat, jestli je v Pages v úpravě písma také něco jako horní či dolní index.. děkuji:)
iPhone 4 16GB Black 4.3.3
iPad 2 32GB WiFi + 3G White 4.3.3 JB
Pages - zkratky??
nie
aramis1
co je to "Cmd" ?
OT: jinak.. jak se da zmenit barva textu ?
vlastním ještě iPhone 3GS bez JB
utraceno v App Store 25,12+ €
Lincoln Six Echo
Klávesa.
- iPhone 6s
- AirPort Extreme 5th gen
