FLAC v iPhone
Martynez | úte říj 19, 2010 2:39 am
FLAC v iPhone
Tak je to tady dámy a pánové... Konečně slušná aplikace na přehrávání FLAC v iPhone/iPad:
http://itunes.apple.com/ie/app/flac-pla ... 32592?mt=8
Music
18.12.2018 18:07
Velikost: 7 MB
Cena: US$ 9.99
Hodnoceni: 3.5
od 155 lidí
Dan Leehr L.L.C.
FLAC Player 2.2.0
The Original audiophile-quality music player designed for lossless, gapless playback of FLAC albums and live recordings on iOS.
Redesigned and Re-engineered, optimized for modern iOS
FLAC Player can download from SFTP Servers - including any Mac with Remote Login, NAS devices, or other systems running SSH. Transfer your music wirelessly and start listening to one track while the rest download.
Loading music over USB is fast and organization is automatic. Files are grouped into collections based on FLAC tags, or file names (if tags are not present). Quickly add music, artwork, and track lists using iTunes USB File Sharing.
- Lossless, gapless FLAC playback engineered for iOS
- Decodes FLAC files at full quality/resolution including 24-bit/96kHz, with onboard playback up to 16-bit/48kHz.
- 24-bit/96kHz and higher playback with USB DAC and Camera Connection Kit (Now supports iPhone, see website)
- 10-Band Equalizer, 21 built-in presets or create your own
- View FLAC Metadata, Stream Info, and Audio Hardware info
- Secure SSH/SFTP connections with private key authentication
- Create, edit, and listen to playlists of FLAC music
- Browse/Play by Album and Artist
- Play/Shuffle your entire collection
- ReplayGain support
- Bookmark any song and jump back later
- Background playback and SFTP Downloads
- Compatible with remote controls (headset or external control)
- Supports bluetooth headphones and audio devices (not recommended for quality)
- Supports AirPlay audio output including Apple TV 2/3 and AirPort Express
- Album art viewer (jpeg, png, tiff, bmp, gif)
- Text/Info file viewer (txt, pdf, html, doc, rtf)
- View info files on SFTP servers prior to downloading
- Sort FLAC files by track number, file name, date modified, or manually
- Optimized for low power-usage
iPhone 3Gs 32GB > iPhone 4 32GB > iPhone 4s 64GB > iPhone 5 64GB > iPhone 5s 64GB > iPhone 6 plus 128GB > iPhone 6s plus 128GB
iPad 2 32GB
Macintosh IIvx > Power Macintosh 7100/66 > G4 > Mac Pro > iMac 27"
Apple TV2 > Apple TV3 > Apple TV4
ned dub 11, 2010 2:49 am
Uživatelský avatar Colpeas | ned lis 14, 2010 5:55 pm
Re: FLAC v iPhone
No hurá, jenom škoda, že to nevydali tak o půl roku dřív, když jsem všechno konvertoval do ALACu...
ned zář 20, 2009 9:26 am
Uživatelský avatar Metalgirl | ned lis 14, 2010 5:59 pm
Re: FLAC v iPhone
Stejně to nestojí za to, ani playlisty to neumí. Jsou tam sice nějaké bookmarks, ale nepřišla jsem na to jejich kouzlo. Jelikož to jaksi z toho bookmarks nepřehrává, měla jsem totiž za to, že to je náhrada playlistů, nastrkám do bookmarks, co chci, aby se mi po sobě přehrálo, ale ono nic.
Lincoln Six Echo | sob lis 20, 2010 12:08 am
Re: FLAC v iPhone
No hurá! Konverze FLAC -> ALAC trvá pro každé album pár sekund. To musí mít super mít v iPhone sto padesát čtyři přehrávačů na FLAC, AVI a nevím co ještě.
pát čer 25, 2010 8:53 pm
Uživatelský avatar Colpeas | sob lis 20, 2010 5:28 pm
Re: FLAC v iPhone
eRipper: jasně, konverze trvá jenom pár vteřin, ale vem si, že takhle konvertuješ třeba 300 alb... zase ALAC aspoň můžeš mít v iTunes knihovně, takže si tu app pořídit nehodlám.
Martynez | úte lis 23, 2010 12:25 pm
Re: FLAC v iPhone
take mam vsechno v ALAC, ale nektera alba mam ve 24/96 a ty po prevodu do ALAC sice hraji v itunes, ale nesynchronizuji se do iPhone, protoze iphone ten tok nezvlada..asi. Pak vyuziju tenhle prehravac :-)
iPad 2 32GB
Uživatelský avatar Metalgirl | úte lis 23, 2010 4:12 pm
Re: FLAC v iPhone
Hmm a tenhle přehrávač to stejně srazí na klasiku 16bit a máš to stejně k ničemu, jelikož sice dokáže přehrát 24/96, ale výstup je 16bitový. :wink:
To už je lepší konverter, co umí z 24 bitů rovnou udělat 16.
Uživatelský avatar Colpeas | úte lis 23, 2010 8:21 pm
Re: FLAC v iPhone
iPody nemají dostatečně dobrý audio HW/zesilovač na to, aby bylo 24/96 rozeznatelné od 16/44,1...
ani sebelepší sluchátka ti s tímhle nepomůžou - vyzkoušeno (beats by dre studio), na hifi ale rozdíl slyšet pochopitelně je
Uživatelský avatar Metalgirl | úte lis 23, 2010 8:38 pm
Re: FLAC v iPhone
No proto říkám, že to tam cpe zbytečně. :wink:
Uživatelský avatar Colpeas | úte lis 23, 2010 10:39 pm
Re: FLAC v iPhone
Jo tak to jo, sorry :) Stejně není nad lossless audio... :) ALAC 4life :D
mikkke | pát pro 24, 2010 11:11 pm
Re: FLAC v iPhone
Taková malá technická, když budu mít přehrávač na FLAC v Ip 4, můžu si FLAC v něm přehrát, ale jak ten FLAC dostanu do Ip 4, když iTunes ho nepodporuje? Jde to nějak obejít a tu muziku dát do Ip 4 jinak? Díky.
Uživatelský avatar Design | pát pro 24, 2010 11:43 pm
Re: FLAC v iPhone
Co spolehlivého a jednoduchého používáte na převod flac na alac?
Practice makes perfect
Twitter @Gabrieluss
úte zář 23, 2008 5:11 pm
Lincoln Six Echo | pát pro 24, 2010 11:58 pm
Re: FLAC v iPhone
XRecode II (Win), XLD (Mac)
Uživatelský avatar Metalgirl | sob pro 25, 2010 12:20 am
Re: FLAC v iPhone
Souhlas s Lincoln. Xrecode II
Uživatelský avatar Design | sob pro 25, 2010 12:37 am
Re: FLAC v iPhone
Xrecode se ukázal jako perfektní volba. Moc šikovný nástroj.
Jsem klasická mp3kař, ale pár FLACu na disku ještě mám, tak aspoň porovnám kvalitu.
Twitter @Gabrieluss
Uživatelský avatar Colpeas | sob pro 25, 2010 10:39 pm
Re: FLAC v iPhone
No, já tedy před xRecode II upřednostňuji dbPoweramp (win), ten totiž konvertuje ALAC do VBR - proměnného bitrate, takže při zachování stejné kvality šetří místo. XRecode to dělá CBR a všechno kóduje jako 1411kbps. na powerampu se na některých písničkách dostanu ve výsledné velikosti až o několik MB níž než v Xrecode. A nikdo z vás nepozná rozdíl, ani kdyby se rozkrájel, to garantuju.
na Macu taky používám XLD, ale spíš když konvertuju muziku pro někoho jiného do mp3, na souborech totiž děla takový "vodoznak" - v iTunes mi to vždycky nutí neodstranitelnou položku "Encoded with" :D ale to je jenom detail :D jinak taky pracuje s VBR
Uživatelský avatar Design | ned pro 26, 2010 11:47 pm
Re: FLAC v iPhone
Upřímně řečeno nepoznám rozdíl mezi MP3 320kbps a ALAC na svém iPhone a sluchátky za 1800. Pravděpodobně hudební hluch.
Twitter @Gabrieluss
Uživatelský avatar Colpeas | ned pro 26, 2010 11:55 pm
Re: FLAC v iPhone
OT: malý rozdíl tam určitě slyšíš ;) u něčeho je to znát více, u něčeho méně... Já mám v ALACu pro jistotu všechno, aspoň si můžu být jistej, že mi vážně neunikne NIC :)
Uživatelský avatar Metalgirl | pon pro 27, 2010 1:16 pm
Re: FLAC v iPhone
Vetsinou u mp3 chybi vysky. Mp3 vice duni a jeste to jde poznat v tech detailech, ktere v mp3kach zmiznou. Clovek pak posloucha ALAC a rika si, ty jo tam jsou jeste klavesy? Nebo tam je vokal v pozadi? Predtim jsem to tam neslysel. Proste u takove tanecni hudby, kde jsou dvoje klavesy, automaticke bici a zpev to je jedno, ale u takove vicevrstvene hudby s hodne detaily uz to jde ten rozdil poznat. Takovy sympho metal. Dvoje kytary, plus baskytara, plus klavesy, bici a smycce, plus efekty ve zpevu, tak tam rozdil mezi mp3 a ALAC ci FLAC jde uz poznat. Ale co me spis trapi je mastering kapel, to tam vetsinou delaji hlucha polena. U blbeho masteringu ani nejlepsi kvalita nepomuze. Je jen par metalovych kapel, co maji fakt dobry mastering. :( No ale to uz sem nepatri.
Uživatelský avatar Colpeas | úte pro 28, 2010 12:31 am
Re: FLAC v iPhone
OT: mizernej mastering řeším ripem z vinylový desky ;) Např. Californication od RHCP ze z CD vůbec nedá poslouchat, na vinylu ale mají tóny správnou barvu. Stejně tak tomu je i alb od OASIS vydaných před rokem 2001 a mnohých dalších. :(
Nechápu lidi z vydavatelských společností, že takovej bordel pustí do světa, že si na ten mastering nedají pozor. Taky je mi záhadou, jaktože na vinylu je mastering v pořádku.... :?: /OT
Uživatelský avatar sharkee | pát zář 15, 2017 2:08 pm
Re: FLAC v iPhone
Tak nové iPhony nově podporují FLAC!
Přehrávání zvuku
Podporované formáty zvuku: AAC‑LC, HE‑AAC, HE‑AAC (v2), chráněné AAC, MP3, Linear PCM, Apple Lossless, FLAC, Dolby Digital (AC‑3), Dolby Digital Plus (E‑AC‑3) a Audible (formáty 2, 3, 4, Audible Enhanced Audio, AAX a AAX+)
Uživatelem konfigurovatelný limit maximální hlasitosti
sharkee
iPhone8 + iPAD2018/iPad mini2WiFi + MBP2018TB + MBA2014 + AW3Nike+42 + aTV4 + BeatsSOLO3WL + AirPods2019WC
pát lis 25, 2011 11:19 am
Zpět na Hudba
