iMovie [AppStore]
JackieTran
iMovie [AppStore]
iMovie pro iOS 4 je jiz k dispozici!
Cena : $4.99
http://itunes.apple.com/us/app/imovie/id377298193?mt=8#
[itunes=377298193]Make beautiful HD movies anywhere with iMovie, the fast and fun moviemaking app that puts everything you need to tell your story at your fingertips. Browse and play projects in the Marquee view. Create Hollywood-style trailers or sophisticated home movies in minutes.* And share your finished projects with the world — straight from iMovie.
Made for Multi-Touch
• Tap to add video, photos, music and sound effects
• Drag to trim the length of any clip
• Pinch to zoom the timeline
• Swipe down on the playhead to split a clip; swipe up to freeze a frame
• On iPad, pinch vertically to open the Precision Editor
Build Hollywood-style film trailers
• Choose from 12 trailers with stunning graphics and original scores by some of the world's top film composers*
• Customise film studio logos, cast names and credits in Outline view
• Add and adjust videos and photos in Storyboard view
• Add existing content from your library, or record new footage straight into your trailer
Create beautiful HD movies
• Choose from a selection of eight unique themes, each with its own set of titles, transitions and music
• Add videos and photos from your library, or shoot directly into your timeline
• Let the Ken Burns effect automatically animate your photos, or pinch and drag to create custom pan-and-zoom effects
• Craft a soundtrack using included music and sound effects, songs from your own music library and audio that you record straight into your project
• On iPad, view colour-coded audio waveforms for every clip in your project[/itunes]
POZOR! pouze pro iPhone 4!!
Cena : $4.99
pistak
- iPhone guru
Re: iMovie [AppStore]
A nezabudni dopísať, že len pre iPhone 4
Jaro
myslíte že to pôjde ...aj na normálnom 3GS ? ... s novým iOs ?
->Macbook Air 2013
->New Ipad 64Gb 4G White
->Iphone 4S White
->Iphone 4S White
JackieTran
Jaro
ok chápem ...ale prečo by to nemohlo ísŤ ? ... hm ? ..to by ma zaujimalo
->Macbook Air 2013
->Iphone 4S White
->Iphone 4S White
Gs.Sk MiKe.CzE
fungovat by to mohlo
ale bylo by to pomalý i na 3GSku a uz jen slova pomalý a apple fakt nejde dohromady, urcite v tom bude i "troška" marketingu
... ale nejspis kdyz pockas tak se to nekomu podaří nejak obejít a dá to do cydie
JackieTran
Jiste ,ze to pujde,ALE nebude to ono,jelikoz 3Gs ma mensi ramku,je slabsi nez iP 4. Proste NE,apple vi co dela.
Xilias
Ja sem iMovie rozjel na 3G .zalozim novy projekt. vyberu si v jakym to chci stylu ... videa nelze pridat. pac 3g nema nataceni videji samozrejmne a kdyz pridam fotku .. stane se ze program se uplne sekne a zacne pokazde padat... takze na 3G nefunguje ..
ale zpustit sel ..tak nevim treba na 3Gs pojede jen sekane .. ale treba pojede...
.:sO ENjoy:.
iPhone 3G 16GB 4.2.1
iPad (3rd generation) 32GB Wi-Fi 7.0.0
Golf
Další "chytrolíni", chytřejší než samotný Apple, co se diví... Proč to asi nezvládá ani iPad? Co se třeba podívat i jinam, proč tomu tak je? Třeba tady...
iPhone 13 Pro Max
MBA 2014 13" i5 8GB RAM
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW5 44
Mac mini 2021
iPhone 13 Pro Max
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW5 44
Mac mini 2021
Kyle
Na 3GS iMovie funguje celkem v pohodě: http://v.youku.com/v_show/id_XMTg1NTIwOTAw.html
Golf
Celkem v pohodě
Možná 80% uživatelů by to schrouplo, ale pokud je mi známo, tak Apple má dost jiné představy o plnohodnotném fungování a hlavně rychlosti a dopadu na celý systém. 3x nebo 4x tapnutí na tlačítko, než se to rozjede, export pouze do nejhoršího rozlišení. Proč to asi není ani pro iPad s gigovým procesorem?
JB je celkem fajn, ale díky němu a nenažranosti a nesoudnosti uživatelů s tím má kdekdo problém, stačí sledovat tohle fórum. Problémy, s kterými jsem se ani jako uživatel JB v životě nesetkal, a proč? Protože vím, co si můžu dovolit a na rozdíl od řady jiných to nepřeháním.
Jinak doporučuji návrat k WM, tam si opravdu může každý zmršit systém i bez velkého laborování, stačí k tomu opravdu hodně málo (obyčejné používání!)...
iPhone 13 Pro Max
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW5 44
Mac mini 2021
iPhone 13 Pro Max
iPad Air 3 64GB LTE
Powerbeats Pro
Apple TV 2G + 4G
AW5 44
Mac mini 2021
Kyle
A můžu se teda zeptat, proč by to neměl zvládnout iPad, když má stejný processor jako iPhone 4 a jen o malinko větší rozlišení?
mettzed
páč iPad má 256 RAM ale iPhone 4 má 512 RAM !
Drago
Tu je navod ako spojazdnit iMovie na iPhone 3GS (jailbreak potrebny)
http://www.cultofmac.com/how-to-install ... -3gs/49047
iPhone 6 64GB Space Gray
MacBook Air 13" Mid 2013
iPad 2 32GB WiFi Black
maros2710
netreba to vobec skusat, ide to extra pomaly cele a viac nez 30 sekundove video nejde exportovat - zasekne sa mi iphone:) apple vedelo co robi, i ked podla mna to neni zas tak narocna aplikacia, len je proste nakodena pre iphone 4 (scvhalne)... takze usetrite peniazky a nekupujte;)
Original iPhone -> iPhone 3GS -> iPhone 5
Kubajs1
Můžu se zeptat jak přidám fotky nebo videa co jsem vyfotil/točil už dříve do iMovie ?? Když otevřu iMovie a chci vytvořit nový projekt tak tám ty fotky ani videa nemám. PLS poradte někdo díky
bohem
trochu OT:
možná by to zasloužilo samostatné vlákno, ale ty dotazy kterých je většina a jsou stále o tomtéž, jsou zavádějící a vlákno o zajímavé app. degradující.. Od příchodu IP4 stále ve všech vláknech stejné dotazy a půjde to na 3GS a na 3G ? a na 2G?
Copak je na tom těžkého k pochopení? Je představena nová F1čka s tím, že se jedná o F1čku a Trabanty to co ona nemohou zvládnout a hned padají otázky: a můžu si na trabanta dát kola s té F1 čky? odpověď: ano můžeš.. a můžu si napasovat na Trabanta volant s té nové F1čky? odpověď: můžeš. A bude mi to potom jezdit jako ta nová F1čka? odpověď: nebude..
Je to stále dokola: vlákno je o iMovie, které je pouze pro IP4, tak co tu kdo řeší jestli mu to půjde na něco jiného? a že prý už to někdo dokázal na něčem pro co to není určené spustit, ale že to stejně nejezdí jako ta F1čka ...-( % .. Tož, smiřte se s tím co máte anebo to prodejte sežeňte si tu novou "F1čku" a neřešte.. a nebo si vytvořte vlákno: "Snažíme se narvat všechny možnosti IP4 do hardwerově slabších, starších modelů" a tam to řešte, zkoumejte a testujte.
sry
jinak dávám odkaz na pěkné video natočené v IP4 a komplet setříhané v iMovie v IP
sry
jannyboy
Přesně napsáno, iMovie pouze na iPhone 4, netřeba řešit jestli pošlape někde jinde, to je jako multitasking, přes jailbreak sem ho dal i do ipodu touch 2g, ale prostě to nešlape, jak by mělo
Kubajs1
Lidi řekne mi někdo?? Já potřebuji dostat do iMovie fotky a videa pořizene před přidáním aplikace ?? Nikde to nemůžu najít. PLS
edit : vyřešeno
Je to pecka programek
edit : vyřešeno
Thomas_A._Anderson
je nejaká možnost jak zakoupit z USA storu, kdyz mam CZ ucet?
To nelze, každá ta země má svůj store, pokud chceš nakupovat v US appstore, tak musíš mít založený účet i v US appstore.
Thomas_A._Anderson
To nemám, nejde mi tam vyplnit karta, nevím z jakého důvodu... a nemáš náhodou ty? ze by jsme to mohli vyresit darovanim aplikace a predovem penez na ucet?
Sorry za OT
Necituj předchozí příspěvek. sweet22
Sorry za OT
No problém je v tom, že tam mám posledních $0,7 Ale když pěkně požádáš tady, tak ti jackietran nebo dodulo založí us account. viewtopic.php?f=90&t=23970
Thomas_A._Anderson
No, taky jde o to, že iMovie je placená app, a založit si US učet umím taky, ale bude jen na free, stejně tak, jako v tematu, co jis mi zde postnul
Ano, jenže se dají k Us account dokoupit gift cards, pomocí nich si vložíš sumu peněz na účet a pak kupuješ.
2L8
Rozbehal uz niekto iMovie na 3G?? Lebo nasiel som video, ze to ide. Mne sa ho tiez podarilo spustit a aj vybrat fotku, vsetko bez chybycky islo, nesekalo (animacie pri pouzivani), ale akosi sa potom sekol a nechcel ist dalej
Ide to niekomu??
http://www.youtube.com/watch?v=4AXfyjkJ ... re=related
http://www.youtube.com/watch?v=W3uVcChY ... re=related
JackieTran
Proboha
,podivej se na HW iP3G a iP 4 a pak si premyslej jestli to "pujde" ..
"iMovie for iPhone 4" .. ach jo.
2L8
Jackie: tak potom na tom videou sa jedna o fake asi
Ja samozrejme viem, ze IP 3G a IP 4 su nezrovnatelne, ale tak na videu je vidiet, ze sa jedna o 3G
a ide mu to.
Cyllon
Poradí někdo kam se ukládaj videa /hotová/ z iMovie ? V telefonu to video vidím v obrázkách ale v PC? Jak to mám z telefonu dostat? Díky moc
STepik
export na youtubbe...
Juramac
Nevim jak ip4, ale z 3GS se videa ukladaji spolecne s fotkami do obrazku a tak se i logicky importuji do pocitace tam, kde mas nastavene v nastaveni iPhone v iTunes ukladani fotek. Predpokladam, ze u iP4 to bude stejne. U PC nevim, v macu je ti iPhoto a nebo Aperture.
Jinak- moderatori,nechci vam moc kecat do prace ale nechcete tohle vlakno promazat od tech nesmyslu s 3G apod?
Julek
- Administrator
ee jen to tu nechte, opakujicí dotazy lidí, kteří si ani neumí přečíst co je zde napsáno a ptají se na to samé znovu, mně nutí k úsměvu
ještě čekám kdo se zeptá, proč mu to nejde na 2G
ninjar0hlik
iphonemato
No mne to funguje aj na 3GS v pohode strihanie videa,sekvencie ,hudba,fotky
Proste vsetko perfektna aplikacia pouzival som MovieMaker ale to nebolo ono
iMovie je super
iMovie je super
PeterKiss
POZOR vy ktorý neviete pochopiť že iMovie nieje na iPhone 3 GS!!
video edit
táto aplikácia je na iPhone 3 GS dal som to aj sem aby ste to videli a nepitali sa furt že či iMovie ide na 3 GS nejde!!!
Ale
http://click.linksynergy.com/fs-bin/cli ... 3D8&u1=web toto!!! Je výlučne na 3 GS.
Takze ak Vám niektorý z moderátorov dá ban necudujte sa prečo iMovie je na IPHONE 4!! kapišto.
video edit
Ale
mettzed
a umí ten video edit to co iMovie
