openssl passwd -crypt -salt /s noveheslo
kde noveheslo je tvoje nove heslo, ktere muze byt dlouhe maximalne 8 znaku (ja jsem v tomto prikladu pouzil ahoy)
vygenerovany kod /sO9wAnFTlYyI jsem umistil do souboru /etc/master.passwd u uzivatele root i mobile
stary soubor:
# User Database
# Note that this file is consulted when the system is running in single-user
# mode. At other times this information is handled by lookupd. By default,
# lookupd gets information from NetInfo, so this file will not be consulted
# unless you have changed lookupd's configuration.
nobody:*:-2:-2::0:0:Unprivileged User:/var/empty:/usr/bin/false
root:/smx7MYTQIi2M:0:0::0:0:System Administrator:/var/root:/bin/sh
mobile:/smx7MYTQIi2M:501:501::0:0:Mobile User:/var/mobile:/bin/sh
daemon:*:1:1::0:0:System Services:/var/root:/usr/bin/false
unknown:*:99:99::0:0:Unknown User:/var/empty:/usr/bin/false
_securityd:*:64:64::0:0:securityd:/var/empty:/usr/bin/false
novy soubor:
# User Database
root:/sO9wAnFTlYyI:0:0::0:0:System Administrator:/var/root:/bin/sh
mobile:/sO9wAnFTlYyI:501:501::0:0:Mobile User:/var/mobile:/bin/sh
po provedeni teto zmeny mi fungovalo prihlaseni pres winscp s novym heslem, ale nedalo se prihlasit pres terminal. odinstaloval jsem SUID Lib Fix 1.0 a nainstaloval jej znovu. po jeho opetovne instalaci jiz funguje i prihlaseni do terminalu.
vychazel jsem z navodu na macosxhints, diskutovat u tomto tematu muztete tady
omezeni: maximalni delka hesla 8 znaku, nutnost pristupu ke konzoli nejakeho unixoveho stroje
