Tak pre vsetkych co sa po update na firmware 1.1.3 a vyssi maju problem pripojit na Ad-Hoc Wi-Fi som natrafil na riesenie, takze:
1. Z /var/preferences/SystemConfiguration/ si stiahnite dva subory: com.apple.wifi.plist a com.apple.network.identification.plist
(sposob necham na vas, ci uz SHH,alebo nejakym managerom...)
2. V nejakom XMLeditori (ja som pouzil editor, neviem, mozno to pojde aj v nejakom obycajnom textovom, ale neskusal som!) otvorte com.apple.network.identification.plist a pod klucom <key>ServiceID</key> by ste mali najst ID kod vasho pripojenia (tvar xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx = proste zlozeny z pismen a cisel).
Tento kod si niekde skopirujte.
3. V editori otvorte tentokrat com.apple.wifi.plist - ten by mal vyzerat nejak takto:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>AllowEnable</key>
<integer>1</integer>
<key>Custom network settings</key>
<dict>
<key>NAZOV VASHO AD-HOC PRIPOJENIA</key>
<string>ID KTORE SME ZISKALI PREDTYM</string>
</dict>
<key>JoinMode</key>
<string>Preferred</string>
<key>List of known networks</key>
<array>
<dict>
<key>AGE</key>
<integer>340</integer>
<key>APPLE80211KEY_BSSID_CURRENT</key>
<string>MAC ADRESA WIFI ADAPTERU</string>
<key>APPLE80211KEY_BSSID_SAVED</key>
<key>AP_MODE</key>
<key>ASSOC_FLAGS</key>
<integer>3</integer>
<key>BEACON_INT</key>
<integer>10</integer>
<key>CAPABILITIES</key>
<integer>34</integer>
<key>CHANNEL</key>
<integer>6</integer>
<key>CHANNEL_FLAGS</key>
<integer>8</integer>
<key>HIDDEN_NETWORK</key>
<false/>
<key>NOISE</key>
<integer>0</integer>
<key>RATES</key>
<array>
<integer>2</integer>
<integer>5</integer>
<integer>11</integer>
<integer>9</integer>
<integer>12</integer>
<integer>18</integer>
<integer>24</integer>
<integer>36</integer>
<integer>48</integer>
<integer>54</integer>
</array>
<key>RSSI</key>
<integer>67</integer>
<key>SSID</key>
<data>
NAZOV PRIPOJENIA V BASE64
</data>
<key>SSID_STR</key>
<string>NAZOV PRIPOJENIA</string>
<key>WEPKeyLen</key>
<key>authMode</key>
<key>isWPA</key>
<key>scanWasDirected</key>
<false/>
</dict>
</array>
<key>SignalStrengthThreshold</key>
</dict>
</plist>
4. Zavrite a ulozte si to.
5. MAC adresu svojho wifi adapteru ziskate vo windowse tak, ze na aktivne pripojenie kliknete pravym tlacidlom mysi - stav - podpora - podrobnosti - Fyzicka adresa.
Nazov vasej siete v base64 ziskate napriklad na stranke
Kód: Vybrat vše
http://makcoder.sourceforge.net/demo/base64.php
napiste tam nazov svojho pripojenia (DODRZUJTE VEKE MALE PISMENA!!) a stlacte "Encode"
6. Nahrajte a prepiste subor com.apple.wifi.plist naspat do iPodu, odpojte sa od wifi a znovu zapojte ....
NEZABUDNITE SI PREDTYM TIE SUBORY NIEKDE ZALOHOVOAT!!!!(clovek nikdy nevie)
Robite to na vlastnu zodpovednost (ozaj len pre istotu, na 99,9% si nemozete s iPodom nic pravit zle, ak postupujete podla navodu)
Dufam ze aspon niekomu to pomoze.
[EDIT]: Malo by to fungovat aj s iPhonom.
