navod od uzivatele mefistos: viewtopic.php?f=13&t=56236
mefistos píše:http://greenpois0n.com/ stahujte
postup
How To Use Absinthe 2.0:
1. Make a backup of your device in iTunes by right clicking on your device name under the ‘Devices’ menu and click ‘Back Up’.
2. Once your backup is complete return to your device and go to Settings – General – Reset – Erase all Content and Settings. This will make the jailbreak process much faster.
3. Open Absinthe and be sure you are still connected via USB cable to your computer.
4. Click ‘Jailbreak’ and wait…. just be patient and do not disconnect your device.
5. Once jailbroken return to iTunes and restore your backup from earlier. Right click on your device name under the ‘Devices’ menu in the left panel of iTunes and click ‘Restore from Back Up…’ then select the latest backup you created before. (restoring this backup will return all the content previously on your device ie, apps, photos, etc.)
6. Thanks for using Absinthe, enjoy your jailbroken iDevice!
Podporovana zarizeni!! aby se predeslo otazkam typu "a jde to na tenhle telefon a tenhle ipad?"
Pad1,1 – 2,1 – 2,2 – 2,3 – 3,1 – 3,2 – 3,3
iPhone2,1 – 3,1 – 3,3 – 4,1
iPod3,1 – 4,1
(Support for iPad2,4 will be added at a later date)
kdyby to neslo stahovat tu mate zalozni linky
http://www.mediafire.com/#q4uppq48sa3yx
http://czshare.com/2954865/absinthe-win-2.0.zip
http://ulozto.sk/xxdwfmD/absinthe-win-2-0-zip
http://uloz.to/xBaLBRk/absinthe-win-2-0-zip
http://dl.dropbox.com/u/44205430/absinthe-win-2.0.zip
puvodni prispevek:
tommi22 píše:Takže downgread 4s přesně podle návodu z 5.1.1 vše proběhne ale na konci Iphon zůstane vyset v recovery. Už to nekdo zkoušel?
Zkus nejdřív udělat restore na 5.1 (mělo by to jít ještě ofiko). Pak na 5.1.1 a pak v redsn0w pro výběr SHSH v sekci "Blobs" zkus dát remote.
Nic jinýho mě nenapadá. Taky musíš brát, že nový erdsn0w je b1, tak je dost možné že v tom budou ještě nějaké bugy.
