WinterBoard nejde
Michal lol
WinterBoard nejde
Příspěvek od Michal lol »
mám problém když se na iPod touch 4G 4.3.3 redsnow RC16 pokusím spustit winterboard (který jsem tam nacpal přec pc) tak mi hned spadne a když se pokusím naistalovat winterboard z cydie říká to: Modifications: Install Mobile substrate, pincrush Reinstall: WinterBoard Remove: FakeOperator
Winter Board
Depends:preferenceloader
Depends: libhide >=2.0.4
nevíte co stím?
PeterKiss
Re: WinterBoard nejde
Příspěvek od PeterKiss »
Máš odinstalovat fake operátora.
Michal lol
ještě pořád mi to píše
Modifications:
Install: WinterBoard
WinterBoard:
Depends:libhide >=2.0.4
PeterKiss
A skúsil si ho odinstalovat cez ifile prezrieť systém či tam niečo neostalo (reštart) a odznova install ?
Edit : pozri toto
http://forums.macrumors.com/showthread.php?t=1028413
edit 2 : Originally Posted by graceypoo
Hello! I tried rebooting my iPhone 4, but Winterboard [along with some other apps] aren't working... It still says:
"Note:The requested modifications cannot be applied due to required dependencies or conflicts that cannot be automatically found or fixed.
Modifications
Install pincrush
winterboard
(this next area is greyed out)
Winterboard
Depends preferenceloader
depends libhide>=2.0.4"
PLEASE help! THANK YOU SO MUCH!! =)
I find out the solution of this problem
First, open Cydia, in tab Cydia you select Home (if needed). Then scroll down, select more package sources. In the default sources, you choose Big boss ^^.
Then, switch to Search (also in Cydia), type preferenceloader, pincrush, and libhide in search box, install it. Tada, now you can install Winterboard.
My english is very bad because I'm in Vietnam, so I'm very sorry if you don't understand me ^^!
Naposledy upravil(a) PeterKiss dne ned čer 05, 2011 3:13 pm, celkem upraveno 1 x.
Michal lol
jo všecko delete
PeterKiss
Pozri môj edit ^
Michal lol
Dík už to jede
