PDF to Pages
Uživatelský avatar cuting | úte říj 04, 2016 10:22 am
PDF to Pages
Podobných programů pro převod pdf do Pages je spousta, některé i free, ale tento mne skutečně zaujal svou jednoduchostí a přesností. Možná se bude někomu hodit. Osobně jsem za 5 USD spokojený :)
https://itunes.apple.com/us/app/pdf-to- ... 6158?mt=12
Velikost: 5 MB
Hodnoceni: 2.5
od 7 lidí
@ PowerfulPDFSoft Inc.
PDF to Pages Converter Expert 2.5.0
PDF to Pages Converter for Mac is the best PDF tool for Mac users to convert PDF files to Pages quickly and efficiently. It does a perfect job in keeping the original PDF formatting and layout in the output iWork Pages documents. The conversion can be finished automatically without any manual intervention. After the conversion, you’ll see the output Pages look exactly the same with the original PDF files.
PDF to Pages Converter Expert helps you to:
*Convert PDF into Pages(.pages), Image(.jpg,.png,.bmp,.gif,.tiff)and Text file (.txt).
*Kepping the original PDF formatting and layout.
*Preview PDF files before conversion.
*Convert any particular page range flexibly.
Attentation: This version doesn't support OCR, scanned PDF will be converted to image in Pages.
Getting Started
step 1:Drag and drop PDF files into the panel, or click add button to add PDF files for conversion.
step 2:Click setting button in the line of the selected PDF file to set output format.
step 3:Click convert button to convert.
 Apple hračky 
úte čer 07, 2011 8:45 pm
Zpět na Programy a hry pro Mac OS X
